I need some pushrods...
Old Feb 16, 2015 | 05:47 PM
351Cleveland C4's Avatar
351Cleveland C4
I need to buy a set of good high quality heavy duty pushrods for my 351C. What should I get?
I have a summit cam, 484 intake 512 exhaust lift with comp cams 924 valve springs. (About 300lbs open pressure)
My sealed power stock replacement pushrods keep bending. In fact, I'm sitting on the side of the road right now because #1 exhaust rod failed....
Old Feb 16, 2015 | 07:24 PM
351Cleveland C4
I think I found the ones I need.
http://m.summitracing.com/parts/cca-7522-1
Old Feb 19, 2015 | 12:37 AM
mustang81's Avatar
mustang81
Did your engine have been rebuild or the heads rebuild? If your block was deck or your heads were shave you need shorter pushrods.
Old Feb 19, 2015 | 12:49 AM
351Cleveland C4
Nope, all stock geometry.
Old Feb 19, 2015 | 02:02 AM
mustang81's Avatar
mustang81
You should be allright with the one you want to order.
dadsold76
Aug 31, 2012 08:18 PM
nothercrash
Aug 28, 2011 12:53 AM
Lakotas53
Mar 1, 2008 10:38 PM
davesbronco
Jan 16, 2007 06:14 PM
Annihilator
Feb 16, 2005 11:31 PM
