Early 04 HPOP question
Old Feb 16, 2015 | 03:17 PM
Gothere's Avatar
Gothere
Hi all, doing a little work/upgrade on truck, was wondering about the HPOP on an early 04, Manufacture date was 07Jan04.
Wanted to fix any issues with the HPOP, but apparently in my era of 6.0l the HPOP did not come with a STC?
I have also heard that there is a ball bearing in the pump that if heated enough will melt the gasket/grommet holding it in the pump, bearing then can fall into engine...
If this is true, what fixes can be done for this?
New HPOP, rebuilt HPOP, I remember someone mentioned to order a 05 HPOP which would fit and it has the STC and go from there???
Thx
Old Feb 18, 2015 | 08:59 PM
jetjockey99's Avatar
jetjockey99
05 HPOP is not a just bolt it in upgrade if you have the early style pump. I think the best option is the Dieselsite billet pump a little more money but very well built
Old Feb 18, 2015 | 09:10 PM
InmatesRunThePlace's Avatar
InmatesRunThePlace
Thx
I just bought one from Ford when I swapped mine.
Old Feb 19, 2015 | 04:59 AM
Rusty Axlerod's Avatar
Rusty Axlerod
It looks like the ball is a safety device to keep from overpressurizing the HPO system. It gets squirted out if the pump fails a certain way. Check the link in the first post in the thread below for some pictures and discussion on pump failures and possible fixes.
https://www.ford-trucks.com/forums/1...and-a-fix.html
Old Feb 19, 2015 | 11:10 AM
Gothere's Avatar
Gothere
Thx Rusty very good info on this stuff...
rdinmv
May 4, 2019 06:38 AM
thx997303
Apr 13, 2019 02:08 PM
Gothere
Feb 17, 2015 05:14 PM
Orezona
Oct 9, 2009 07:18 PM
