1976 ford f150
Old Feb 15, 2015 | 04:47 PM
william87's Avatar
william87
1976 ford f150
I have a 76 ford f150 with a 390 and I stripped the torque converter bolts off. Is there an easy way to get the converter off of the motor? thank you
Old Feb 15, 2015 | 04:59 PM
HIO Silver's Avatar
HIO Silver
Isn't a torque converter held secured to the flex plate with nuts?
Old Feb 15, 2015 | 05:06 PM
william87's Avatar
william87
yes, i stripped the nuts off.
Old Feb 15, 2015 | 05:13 PM
HIO Silver's Avatar
HIO Silver
I hope you can weld......
Get a nut that is bigger than the TC's stud and weld it to the stripped nut. Let it cool off and yes, loosen counter-clockwise.
Good luck.
Old Feb 15, 2015 | 05:30 PM
william87's Avatar
william87
Is there enough room between the block and the nut to weld another nut on?
Old Feb 15, 2015 | 05:36 PM
william87's Avatar
william87
sorry I understand now turn the motor over until the nut is in the open and weld the nut on. Im going to try it now hope it works. Thanks for the help!!!!!!!
Old Feb 15, 2015 | 06:04 PM
SaveTheCars's Avatar
SaveTheCars
You can also go to your parts store and explain what you have, they have special tools to get the stripped nuts off, just cant remember what their called.. good luck
I tried this 1st before I weld on it, to much of a chance warping the flex plate or starting a oil fire right under the oil & tranny pan
Old Feb 15, 2015 | 07:00 PM
HIO Silver's Avatar
HIO Silver
"Nut splitter"
Warping the flexplate? NOT! It's a series of short tack welds with a MIG welder.
It's oil, not gasoline.... You've been watching too much MSNBC.
Old Feb 15, 2015 | 11:41 PM
bkaul's Avatar
bkaul
Or try something like this:
Shop IRWIN 5-Piece Bolt Grip Set at Lowes.com=
Old Feb 16, 2015 | 09:07 PM
SaveTheCars
relax HIO... Fox News follower... take it easy just a suggestion
PSU4ME
Jul 16, 2019 01:58 PM
herbiemin
May 9, 2015 01:29 PM
03scf250
Mar 5, 2009 09:31 PM
z1121jack
Aerostar
Jun 27, 2008 01:01 AM
jamesjinks
Jul 11, 2004 09:14 PM
