Sponsored by: Real Truck
charging issues
Old Feb 15, 2015 | 02:38 PM
l.g.jr14's Avatar
l.g.jr14
charging issues
97' 250. Just replaced the alternator, test good. Battery is fine. Cant get the atlernator to charge. Voltage regulator maybe? All fuses check out fine. How do you check the voltage regulator? Or maybe other things i should check? Thanks!
Old Feb 16, 2015 | 08:44 AM
DavidB's Avatar
DavidB
Did you replace the alternator with a new/rebuilt alternator or another used alternator?
How did you test the alternator?
The voltage regulator is built into the alternator.
If the alternator is good and the battery is good, but it still is not charging, then you have a wiring harness problem. Possibly an open fused link. Don't ask where to look. Get a wiring diagram and check/test all connections.
The_Josh_Bear
Aug 19, 2018 08:01 PM
CharlsChainCharlson
17
May 18, 2016 06:51 PM
Encho
21
Apr 6, 2013 11:25 AM
dan66tampa
Jan 24, 2005 12:11 PM
rick
Electrical Systems/Wiring
Jul 16, 2000 01:54 PM
