Sponsored by: Auxito
2001 trans limp mode
Old Feb 15, 2015 | 08:26 AM
scottrkind's Avatar
scottrkind
recently my truck went into limp mode. checked out many forums and had some great threads here. from what can figure out is there is a short in my harness, engine panel has blown fuse in 23. should I check the right side by the o2 tube first? it is -5 below so I don't have much time to be outside before I freeze up. by the way it is a 4x4 with a 5.4. thanks
Old Feb 15, 2015 | 02:46 PM
Bluegrass 7's Avatar
Bluegrass 7
Well it's not Limp mode you have.
It's a whole lot of circuits out of power.
Fuse 23 feeds the transmission solenoids,, Ox sensor heaters and some other circuit functions.
If you were to look at codes, there would be a long list of failure codes.
Yes, find the ground out that is blowing the fuse.
Look back around the exhaust for burn or rub-through.
The harness comes up the passenger side to the back of the motor from the trans and sensors.
Good luck.
Old Feb 16, 2015 | 05:05 PM
scottrkind's Avatar
scottrkind
found the short.it was the o2 censor wire on the driver side rubbing on the drive shaft for the front axle. thanks for all the good threads.
Southsideva
Nov 23, 2015 08:52 PM
milwaukee2000
1997 - 2003 F150
Mar 21, 2015 06:12 PM
ktm25094
1997 - 2003 F150
Sep 7, 2011 01:53 AM
jal13232003
1997 - 2003 F150
Jul 8, 2011 09:29 PM
coyote0003
13
Jun 5, 2007 12:45 AM
