Don't do the doo
Old Feb 23, 2015 | 08:56 PM
  #46
Bonanza35's Avatar
Bonanza35
I've never dumped a bucket of oil but I've dropped my filter a couple of times, what a mess. Don't ware plastic coated gloves big mistake.
Old Feb 23, 2015 | 09:37 PM
  #47
bigb56's Avatar
bigb56
I like to wrap a plastic bag around it then finish unscrewing it. Someone said they use a 2 liter bottle with the top cut off but I never have any of those around.
I did have a five gallon jug of waste oil bust open in the bed once....ya that was a nice mess.
Old Feb 23, 2015 | 10:28 PM
  #48
brian42's Avatar
brian42
Veteran: Navy
1. Don't put off investigating a shiny steering knuckle until tomorrow (which turns into over a year) as it's just going to cost more (inner oil seal, stub axle, u-joint, hub assembly, auto-locking hub, and all the o-rings and seals just because the $10 needle bearing dried up and let go inside the hub).
2. NEVER EVER EVER even think about getting under your truck held up by a floor jack without properly placed jackstands!!! I've never done this personally but my dad beat it into me so much as a youngster that the hair on my neck stands up just thinking about it to this day (almost 40 years later).
Old Feb 24, 2015 | 08:59 AM
  #49
Tugly's Avatar
Tugly
While this falls under the category of "General Safety Rules" (not particular to the PS SD), it's still a great safety tip. 8000 pounds on the noggin' will leave an impression on you for the rest of your life (however short or long that may be after the inci"dent").
Oil in the filter... I have a solution:
Old Feb 24, 2015 | 02:00 PM
  #50
brian42's Avatar
brian42
Veteran: Navy
I've not drilled a drain hole but I have used a hammer and screwdriver to make one many a time...
Old Feb 24, 2015 | 03:42 PM
  #51
Bonanza35's Avatar
Bonanza35
I to do this now after dropping two of them in the pass.
Old Feb 25, 2015 | 09:52 AM
  #52
F250_'s Avatar
F250_
I use a rectangular 10 gallon "mixing tub" from Home Depot when changing my oil. (Mixing tubs are used for mixing sheet rock mud or concrete or mortar, and can be found in the building supply section.) It's low and large enough to more than hold what I need to do, plus it covers the main drain pan, main flow filter, as well as my bypass filter locations without having to be moved around. Admittedly, it takes two people to "harvest" the oil from the tub into my 5-gallon transfer bucket (closed lid with a built-in pour spout), but it does simplify the dirtier part of the job under the truck.
Link>>> Plasgad Black Medium Concrete Mixing Tub-887101C - The Home Depot
Old Feb 25, 2015 | 12:17 PM
  #53
Tugly's Avatar
Tugly
I got this at the Irish parts store (6 gallon capacity):
Old Feb 25, 2015 | 01:23 PM
  #54
Glowplugger's Avatar
Glowplugger
Thanks for this idea! I'm going to Lowes tonight to find something similar.
(I can't do HD for so many reasons)
Old Feb 25, 2015 | 01:33 PM
  #55
SpringerPop's Avatar
SpringerPop
It doesn't have anything to do with that time there in the aisle where they sell toilets, does it?
Pop
Old Feb 25, 2015 | 01:43 PM
  #56
Glowplugger
Pop
What, does everybody know?!?!?!
Stupid social media!
Old Feb 25, 2015 | 02:32 PM
  #57
SpringerPop
Not-to-mention a camera in every phone now-a-days.
Pop
Old Feb 26, 2015 | 08:05 AM
  #58
Tugly's Avatar
Tugly
Is this going to be one of those "I'll show you mine if I show me yours" things?
Old Mar 3, 2015 | 04:34 PM
  #59
F250_'s Avatar
F250_
Personally, I'm happy enough with mine, and I just do NOT need to see anyone else's.
Old Mar 4, 2015 | 01:00 AM
  #60
clem1226's Avatar
clem1226
When installing the 42 pin connector in to the PCM be sure it is square to the plug before you push it in. Do not starts in at an angle, it can bend pins and introduce some head scratching.
I shorted my map signal to ground.......
Don't try to work around parts that that can be removed in an effort to save time. As an example you CAN replace the pressure line from the power steering pump without removing the air intake, DS battery/ tray and DS CAC tube but it takes about 15 minutes longer than just getting everything out of the way.......even in a parking lot at 4am.
