Hey guys, i know we have all been through this a time or two. When trying to remove the manifold from the 351W i am building i broke a few of the studs. I tried my best not too. I was using my Snap-On 18v Impact. A couple of them are sticking out past the head a lil bit so i am gonna attempt to weld a nut on so i can get a wrench on there. Any other suggestions? Or is the drill and tap method my most efficient route?
Try a mapp gas torch to get them hot and grab them with vise grips and wiggle back and forth. Spray with PB Blaster or some other good penetrating oil while still pretty warm. Repeat a few times. Tapping lightly with a hammer for a few minutes will break rust bonds too. Any way you slice it, it sucks. Good luck.
Drilling and tapping is always a last resort for me. As long as part of the bolt is still sticking out I'll make every attempt to remove the bolt first before risking damage by drilling off center. If they're broken off flush or down inside the hole you have no other choice though.
I've had the best luck with heat and penetrating oil. Carefully work it back and forth a little at a time until it breaks free.
i agree with rowdy...drilling is a pain in the *** when you dont have a bench and a press to work with. trying to angle drill on the heads with low visibility and poor access will make you lose your mind...
welding a nut on can be successful, still use lots of penetrant. heating is ok as long as you dont get crazy, cast iron doesnt stand up well to excessive amounts.
sounds like a great time to pull the heads and get some gt40 or gt40ps.
lol i think you are right '89. Been considering aluminum but just wanna get the motor in and running before i do anything thats gonna slow the process more. I am a machinist so i have access too anything and everything i could ever need.
Weld a washer to it first and then weld on the nut. The welding not only heats the stud, it also draws it in on itself loosening it up a bit. Be gentle with the wrench at first working it back and forth, don't just try and torque it out the first time. Even if it takes 2 or 3 or 4 times, still WAY better than drilling!
Use plenty of hi-temp anti-seize when you go back with the new bolts. You may have to re-tighten them a couple of times, but you will thank yourself in the future.
that is a REALLY good idea with the washer, never thought of that, I just wend nuts on. I'll have to try the washer next time
Give it a try, you'll like how well it works. With bolts that are broke off flush, use a washer with a slightly smaller hole than the diameter of the bolt. This will help keep you from welding the bolt to whatever you are trying to get it out of!
