Duallys Only
#1564
I got a question for Dually owners. What product do you guys recommend when it comes to valve stem extenders? Amazon has the wheel masters 4 inch straight extenders but I looked at my valve stems a they look a little off angle. I see that they have the braided 7" stainless steel ones and I was wondering if anybody has used them on their rig. Thanks.
#1565
#1566
Received 4,009 Likes
on
I got mine from eTrailer.com
Make life easier.......
#1567
#1568
I got external TPMS sensors and had to use the braided hoses for the inner duals. I used the 135 degree extenders to add the TPMS sensors on the other 4 stems. I drilled into the plastic hub covers to mount the hose and sensor. Before adding sensors, I was able to get to all 6 valve stems with this: Milton Window Inflator Air Gauge — Dual-Head Straight Chuck, 1/4in. Inlet, Model# S-516 | Air Chucks Gauges| Northern Tool + Equipment
#1569
Can you shoot a photo of your setup on the wheel ?
Thanks
#1570
Sure ZooDad. I recently took them off when I found that the batteries in the sensor were being used as long as there is air pressure on them. Each sensor is coded and has to go back on the correct tire so I made this board in a hurry, one day.
I found out that I don't have the SS braided hoses, I have the regular brand "X" hoses! Note a heavy coat of pollen and dust.
And, now I have to be embarrassed at how dirty my truck is!
This is the extension that I have for the rear outer:
I didn't have extensions for the fronts, but that proved to be a pain. I couldn't find the ones like I had on the rear, so I got these:
Bad case of brake dust, huh? Anyway, I hope this helps.
#1574
#1575
Cat Eye and wheel balance
Those of you using the Cat Eye or similar dual tire pressure balancing systems... have you experienced any tire/wheel balance issues?
I am getting a vibration over 75mph and I suspect it is my Cat Eyes... tho I have no idea how I will address the issue if it is in fact the Cat Eyes.
