Wanted
Old Feb 14, 2015 | 08:44 AM
544tess's Avatar
544tess
Wanted
Looking for a drivers side fender alignment rod firewall bracket from a '54 F250.
[/URL]
Old Feb 14, 2015 | 08:56 AM
abe's Avatar
abe
I don't have one now, but FYI, the rods off of F-100 through F800 will be the same. If you can't find one soon, I could get one once the snow melts here in central PA.
Old Feb 14, 2015 | 09:06 AM
544tess's Avatar
544tess
Thank you Abe.
Just to be clear,I need the bracket on the firewall.
I guess it is spot welded on?
Old Feb 14, 2015 | 09:14 AM
CharlieLed's Avatar
CharlieLed
Midfifty part number 2059-PS or 2059-SS if you want polished stainless steel.
imlowr2's Avatar
imlowr2
Unless you want original equipment, I made my own from aluminum rod. I simply tapped the ends and screwed on a eyelet, (similar to the billet ones on alternator brackets). It gives you adjustment of the rod as well and was less than $10 to make. The bracket on the firewall should be just as easy to make, however you'll have to weld that on.
Old Feb 14, 2015 | 09:53 AM
544tess's Avatar
544tess
Exactly what I need,thanks!
Old Feb 14, 2015 | 01:52 PM
abe's Avatar
abe
Originally Posted by 544tess
Thank you Abe.
Oh! I didn't read your post carefully enough! And I guess that is why only the bracket was clear while everything else in the picture was fuzzy!!
Old Feb 14, 2015 | 02:01 PM
544tess's Avatar
544tess
I wanted to circle it but not enough geek in me!
544tess
Nov 29, 2015 08:17 PM
TheStuffz
Jul 2, 2015 10:17 AM
Sillbeer
WTB - Parts & other
Sep 1, 2011 11:40 AM
martydread
24
Sep 29, 2007 09:40 PM
