Bronco II Ford Bronco II
87 Bronco 2 EEC power relay
Old Feb 13, 2015 | 08:14 PM
pawayne63's Avatar
pawayne63
Exclamation 87 Bronco 2 EEC power relay
I need help finding the EEC POWER RELAY
Book said it was next to ecm in p/s kick panel can not find it
Old Feb 18, 2015 | 11:55 AM
exranger06's Avatar
exranger06
It should be in the fuse box under the hood where all the other relays are.
Old Feb 18, 2015 | 02:16 PM
pawayne63's Avatar
pawayne63
thanks will check it out
Old Feb 25, 2015 | 11:15 AM
Josh S's Avatar
Josh S
1st gen's don't have a fusebox under the hood that I'm aware of. What's worse, relays are scattered throughout the engine bay and inner dash. I believe that relay is on the passenger side inner fender beneath a black plastic cover. If I remember right there are a couple relays there. It will be the brown one. Same place the OBD-I system test ports are located. If not there let me know and I can pull out the manuals.
Old Feb 25, 2015 | 07:21 PM
pawayne63's Avatar
pawayne63
found it it was under the hood
djs556
Jul 31, 2020 05:54 PM
870
Dec 27, 2008 05:55 PM
M.Herrington
Aerostar
Oct 12, 2004 03:04 PM
Norm Carter
1978 - 1996 Big Bronco
Sep 1, 2003 05:41 PM
ziggyandspiders
Jul 26, 2003 10:40 PM
