92 idi starting issues.
Old Feb 13, 2015 | 06:04 PM
Big €ountry's Avatar
Big €ountry
Ok guys I have a 92 7.3 and I'm having trouble get it to crank up. It works fine when I have it plugged in over night, but Im certain of an error somewheres. Whether it be bad glow plugs or bad injectors. Maybe even a bad lift or ip pump.
I'll turn the key on and immediately the gp solenoid starts ticking, probly 20 to 30 times when cold... no wts light, no buzz or chime, just ticking. Anyways, sometimes she'll bust off after 5 to 10 seconds of cranking and 2 times of ticking, others I could sit and drain the batteries, but that's when I turn to starter fluid. I know it's horrible and I really try not to do it. So, when she does bust off, it runs really rough and lots of white and or blue smoke. I have been searching google like crazy the past few days and can't find the exact same problems. Any advice would be greatly appreciated. And thanks in advance.
Also, after I turn the truc off, I can hear fuel leaking, possibly back to the tank. I read it could be a cracked injector/body. Can these be visible cracks? Haven't tried cuz i hate taking my injector lines off. But I definitely will if this is possible.
Old Feb 13, 2015 | 06:26 PM
tjc transport's Avatar
tjc transport
i ain't rite
first thing i would do is take a test light or volt meter to a glow plug wire and see if you get power to them at cold engine key on.
it really sounds like the engine probably has autolite glow plugs in it that are burned out.
but it may also be a bad relay or controller.
Old Feb 13, 2015 | 06:31 PM
Big €ountry
Yeah I tried that yesterday. Each gp connector has power only while the solenoid is ticking.
Old Feb 13, 2015 | 06:42 PM
Big €ountry
Also, could bad glow plugs cause excessive smoking
Old Feb 13, 2015 | 06:52 PM
tjc transport
i ain't rite
yes, when cold it will smoke like a pig until it warms up if the glow plugs are not working.
it sounds like the controller and relay are working properly than, and the glow plugs are bad.
motorcraft ZD-9 glow plugs only, you can buy them for $9.12 each from rockauto.com.
Old Feb 13, 2015 | 06:59 PM
Big €ountry
Ok that helps big time! Thanks. I added in my post earlier about my injectors. Do you have any input on that?
Old Feb 14, 2015 | 05:32 AM
tjc transport
i ain't rite
i have never run into a cracked injector body on a ford, but have seen it many times on chevys.
do you know how many miles are on the injectors? service life is around 100,000 miles, but i push them to 150-170k miles before changing them.
CaptainFacePunch
May 14, 2016 08:48 PM
jbwolfe
16
Mar 2, 2016 10:28 PM
Opossum
Oct 17, 2012 12:18 PM
backhoeken
Jul 8, 2007 11:23 PM
tkcollin
Sep 26, 2003 11:30 PM
