Sponsored by: Innova
noise filter
Old Jul 22, 2003 | 06:56 PM
Maxi's Avatar
Maxi
noise filter
Does the '95 Ranger have a noise filter for the stock stereo. AM tunes in nicely with the engine off. Once started the reception gets bad.
Old Jul 24, 2003 | 07:47 PM
smokey6309028's Avatar
smokey6309028
noise filter
AM band is affected by noise much more than FM because it has more devices interfering with it at similar frequencies. Not a whole lot you can do about it, unless there is a frequency filter that you can run inline to try and cut back on some of the interference. Others (Tempe, Optikal,Luvdeftones) may know this ...?
Old Jul 25, 2003 | 06:56 AM
AlabamaBronco's Avatar
AlabamaBronco
noise filter
Have you always had the noise on AM or has it happened over time? Make sure that all of your grounds are good and that your antenna is mounted securely. There are aftermarket noise suppressors available but I dont know how effective they are. Factory radios usually have pretty good AM reception so I am thinking the problem can be corrected.
