Alternator Idiot Light troubles
Old Feb 13, 2015 | 01:24 AM
scb1966's Avatar
scb1966
Smile Alternator Idiot Light troubles
My 66 F100 Alternator idiot light doesn't seem to work. Shouldn't light be lit with the key on and the engine not running. I still get 14.3 volts idling at the battery. Any thoughts. Have a wiring schematic coming on Saturday.
Old Feb 13, 2015 | 08:23 AM
62fordF250's Avatar
62fordF250
After doing a quick visual inspection of the wires and connectors I would check the bulb. You can also check the circuit at the bulb socket. One wire will have voltage with the key on and the other wire will only have voltage when the engine is running.
Old Feb 13, 2015 | 06:05 PM
Speedjester's Avatar
Speedjester
I agree with 62fordf250... Check bulb...
Old Feb 14, 2015 | 10:26 AM
ktnissen's Avatar
ktnissen
Check the bulb, I spent two hours rewiring to find a bad bulb.
Paperman2
Feb 8, 2019 01:27 PM
Ole Green 1978
Feb 16, 2012 08:22 PM
79str8six
Mar 7, 2011 10:05 PM
norvillebob
Dec 6, 2006 07:23 PM
rosa70
Electrical Systems/Wiring
Aug 5, 2005 10:43 AM
