Alternator upgrade, Which brand????
Old Jul 22, 2003 | 06:09 PM
dvldog458's Avatar
dvldog458
I'm looking into upgrading my alternator in my 1991 5.0L. engine.
I was wondering what brand that you guys recommend.
I'm currently running a remanufactured 100 amp alt from a mustang.
I've seen a bunch on Ebay. Any thoughts?
Thanks,
Jerry
Old Jul 22, 2003 | 07:25 PM
lexluthr69's Avatar
lexluthr69
I'm currently running the 130amp alt. I got off ebay from Alterstart. I've had great luck with it, but the install was a slight bit more painful that I thought. I had to use a cold chisel to chop out a portion of the alternator bracket to get it to fit. However, it did come with the lil' plug and a new bolt, which helped the install a bit. I'd buy it again, if I had to.
Luke
Old Jul 22, 2003 | 07:32 PM
dvldog458's Avatar
dvldog458
Luke,
Did you have to upgrade any wiring?
I also had to chop alittle off my alt bracket when i installed the 100 amp alt.
Jerry D
Old Jul 22, 2003 | 07:43 PM
lexluthr69's Avatar
lexluthr69
Instead of using the big "prone to melting" plug, you take two eyelet wire connectors (10-12 gauge) for the main voltage wires, that then get mounted to the stud on the back of the alt. the wire left over attaches to the "lil'" plug, and inserts into the alt.
Now if you meant wiring elsewhere, I run a 2 gauge positive batt. cable, and a 4 gauge neg. batt. cable. All the other wiring, minus all my haphazard gauge wiring, is stock.
Old Jul 24, 2003 | 12:20 AM
dvldog458's Avatar
dvldog458
Are these the same guys you bought yours from?
http://cgi.ebay.com/ebaymotors/ws/eB...category=33573
Old Jul 24, 2003 | 05:11 AM
lexluthr69's Avatar
lexluthr69
Yes, that's the same one I got mine from. Good deal, I think.
Luke
Old Jul 24, 2003 | 02:54 PM
Hit Man X's Avatar
Hit Man X
That's where I got mine from too!
The install is pretty easy. You do have to modify part of the bracket...Dremmel works well, Air powered die grinder, hell even a drill bit and file.
I upgraded the power wire from the alternator to the solenoid from that 10awg crap to a nice 4awg wire. My batt cables are 2awg now.
https://www.ford-trucks.com/user_gal...=17940&width=0
That pic should show all my larger wiring. Look in the back part of the pic for my fuse holder and 4awg alt wire. By the coffee can and jack. You can also see my 4awg amp wire too!
I plan to upgrade to a 180-200A unit before I swap to electric fans. I have a very slight undercharge at idle with the A/C on and the headlights and that would only get worse with 30A worth of fans.
Old Jul 24, 2003 | 06:47 PM
Hit Man X's Avatar
Hit Man X
I think 200A is more than enough. My slight undercharge now is b/c I still have a big ol' alternator pulley on there. I have a tiny 1.75" I need to install.
