Mine with about 2000 miles has about 70lbs cold with 10w40 at idle.
50lbs at idle hot and 60lbs at cruise speed hot. This is with a High Volume Oil pump, but no other oiling mods.
Brian
Mines got 70psi hot at speed after a quickie overhaul with 20W-50. Just went with new rods and mains, left the crank std/std. Oil pump is a high pressure unit/std volume
