Adding Tachometer on 64
Old Feb 11, 2015 | 08:55 PM
64DarkHorse's Avatar
64DarkHorse
I would like to add a tachometer and possibly another gauge like oil pressure to my 64. Can I purchase any analog gauge and have it work. Truck has original 292 and generator. Thanks all.
Old Feb 11, 2015 | 09:18 PM
skidoorulz's Avatar
skidoorulz
Not up on the words. Is analog with a sweeping needle? If so a tach will work fine. Had one before restoring and am putting a Supertach in as wee speak. As far as the oil pressure gauge I put one in mine also but it is mechanical.
Old Feb 12, 2015 | 02:31 PM
64DarkHorse
Yes that's the analog type I want. Issue is do I keep the cluster as is and add the tach to the dash or cut up the panel and add 2 gauges. Also what do I need to purchase with the tach to make it work or does it usually unclude the cable?
Old Feb 12, 2015 | 03:11 PM
charliemccraney's Avatar
charliemccraney
You can do it however you want. Gauges usually come with the stuff necessary for installation. If it does not for some reason, wire can be found locally.
Old Feb 12, 2015 | 05:11 PM
skidoorulz's Avatar
skidoorulz
My tach came with more than enough wire. I mounted it to the steering column. All you need to buy his a 3 inch hose clamp for that. As far as the oil gauge it is mounted in the instrument panel on the right side of the speedometer. On the left side I installed a volt meter. Check out my thread and you will see pictures of the dash. 64 f 100 restoration I believe I titled it.
TheKirbyMan
Oct 25, 2012 04:28 PM
tomtoc
18
May 1, 2007 07:00 AM
god.boots
May 16, 2005 09:21 AM
blackandsilver94
1983 - 2012 Ranger & B-Series
Apr 18, 2005 07:54 AM
