48 F1 Flathead 8 Transmission
I am considering replacing the stock 4 speed in my 48 F1 with the much more quiet, 3 speed. Aside from actually locating a transmission, I'm not familiar with what challenges or options I may have. While I'd like to remain as stock as possible, I am not sure if I can simply locate a 3 speed transmission and bolt it directly to my flathead 8. Is there a range of years or models which are appropriate? Is there a difference between a 3 speed transmission for a 6 cylinder and an 8 cylinder flathead? I do, in fact have a floor shift and intend to keep it that way. Also, I have read where I'd need a different driveshaft. Could the existing driveshaft be modified to accommodate length and/or spline?
Would like to learn from someone who has done this. Thanks for any insights!
The ideal swap would be to a heavy-duty 3-sp, which is also floor shift, works with the same clutch (11"), and has the same type of driveshaft. Unfpotunately, they aren't easy to find.
The light duty 3-sp from a 48-50 will also be floor shift, while a LD from a 51-52 will be column shift. Driveshaft replacement would be required, costs about $200. You may also need to go to a 10" clutch, I can't remember other than there have been problems with certain swaps. A search on here will turn up several threads about it.
DAD'S51
10-13-2016 08:05 PM
52F1Gary
11-07-2014 08:21 PM
