CV Installation Offset
Old Feb 10, 2015 | 07:20 PM
falcain's Avatar
falcain
Trailering
I'm installing a CV front end in my 64.
Looking for feedback on if the center line of the CV assembly needs to be moved forward or back from the original front axle location to keep the wheels centered in the fender wells after the 5" drop. I'll be installing either 17"x8" or 18"x9" wheels.
I just want to make sure the wheels won't be off center once I re install the front clip and fenders.
Any advice would be greatly appreciated.
Old Feb 10, 2015 | 10:44 PM
TxStang2010's Avatar
TxStang2010
the CV centerline on 61-64 needs to be 1" forward towards the bumper from the original axle centerline to center it in the fender opening on those years . Before permanently mounting its a good idea to mock it up with a fender in place anyways to make sure everything is where you prefer it . I have seen some moved an additional 1/4 inch to 1/2 inch forward and looks a little more aggressive if your tire OD still has the clearance .
Old Mar 14, 2015 | 09:18 PM
falcain's Avatar
falcain
Trailering
Just wanted to verify that the new center line for CV front end will be 1" forward from the original front axle on my 64.
Any others that have completed this swap on a 61-64, please chime in.
Thanks
Old Mar 15, 2015 | 02:44 PM
MCD46's Avatar
MCD46
Thanks
I believe I moved mine 3/4" forward of original centerline. I have pictures installed in my gallery.
Goeasybaby10
Jul 4, 2013 09:44 AM
Fastlane1
1961 - 1963 F100 Unibody
Dec 3, 2011 01:05 PM
jred
Dec 11, 2009 12:02 PM
david fantini
Dec 14, 2004 08:15 AM
PJS55
Nov 27, 2002 08:07 PM
