Please Help
Old Feb 11, 2015 | 12:14 PM
Jay Pyles's Avatar
Jay Pyles
Thanks for the info AXracer, I love free and I have decided to take everyone's advice and just get the 3 speed fixed. I may however later on after a few years of driving her around use your suggestion abut the T5. So thanks for the tip and the free catalog. <table width="100%" border="0" cellspacing="6" cellpadding="0"><tbody><tr><td class="alt2"></td><td nowrap="nowrap">
</td></tr></tbody></table>
Old Feb 11, 2015 | 09:24 PM
AXracer's Avatar
AXracer
Ford 3 speeds are very easy to rebuild. pull it down (pick up a Motor's Manual that covers the F1 at a used book store or online for step by step) to see what it needs. Be sure you can get the parts it needs for realistic prices. If you send it off for rebuilding you'll likely spend more than you would for the T5 conversion.
By the way you don't need to remove the cab to replace the rubber cab mounts.
Old Feb 11, 2015 | 10:13 PM
Tedster9's Avatar
Tedster9
Originally Posted by Jay Pyles
Does anyone know where I can get just the letter R?
Nice Fod! Hope this helps
Old Feb 11, 2015 | 10:22 PM
52 Merc's Avatar
52 Merc
The downside to installing a T5 5 speed in the 48-52 trucks is there's a major crossmember in the way and it's relatively major surgery to do the swap. For a beginner, you're better off sticking with the 3 speed for the time being.
Old Feb 11, 2015 | 10:29 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Aside from that, S-10 T5's are no longer plentiful, since everyone wants them for the older cars and trucks. A truly good one (not a worn-out one needing a rebuild) can easily run over $500, plus adapters at $300, plus driveshaft mods, frame mods... it adds up quickly.
Old Feb 12, 2015 | 08:58 AM
tinman52's Avatar
tinman52
Welder User
I should have an extra "R" around here....will take a look.
Old Feb 12, 2015 | 01:58 PM
Tedster9's Avatar
Tedster9
All jokes aside, Mac's has a complete set of Fs, Os, Ds, (and the much coveted "R") ; plus, the special washers used on the 48-50 trucks @ $61.95 ($15.4875 per, plus shipping)
part # 48-10859-2
Old Feb 16, 2015 | 09:55 AM
Jay Pyles's Avatar
Jay Pyles
Awsome
That would be great Tinman52 just shoot me a PM if you find one.
Old Feb 16, 2015 | 10:01 AM
Jay Pyles's Avatar
Jay Pyles
So, this weekend I got under the truck and to my surprise it was very clean with very little rust. I was also able to repair the eBrake. so I'm excited about that, I also decided to not take it all apart and leave it as is. However I'm still debating on the exhaust, any advice on dueling it out? or should I leave it as is and just get a new muffler (Rotted out) and extend the pipe out the back. Also do most people suggest just to keep the original oil bath air filter or do they change it out to a newer style or K&N and if you do keep the original is there any way to keep the oil from slushing out and covering the outside of the carb?
Old Feb 16, 2015 | 10:56 AM
Harrier's Avatar
Harrier
I'm not sure if there is a great advantage to going to dual exhaust if it you are just going to cruise a bit. It's really up to your preference and money available.
For the oil bath air filter, a properly filled filter shouldn't slosh oil out. If you want to convert to a newer style and retain the look take a look at these instructions.
https://www.ford-trucks.com/forums/1...r-cleaner.html
Well, FTE used to have an article on this as well but it was moved or deleted.
Here is a thread where a Ford expert (NumberDummy) explains the oil bath is better than paper, but just harder to clean.
https://www.ford-trucks.com/forums/5...r-filters.html
Old Feb 16, 2015 | 11:10 AM
raytasch's Avatar
raytasch
Believe Nothing
If you're sloshing oil out of the air cleaner you either have it too full or it has a hole where the oil runs out. Rust holes are common if the filter has ever had water blow in on it. Easily repairable.
Old Feb 16, 2015 | 11:46 AM
harleymsn's Avatar
harleymsn
After I had first did Edith and cleaned up the engine and painted everything, I kept getting oil around the carb and manifold. I took the oil filter off and cleaned everything again, then searched everywhere looking for a leak. When I could find nothing I went to put the oil filter back on and found a small spot of oil on my work bench, after careful cleaning I still could not find a hole, but I left the filter on the bench with a small amount of oil in it. A short time later I discovered oil seeping from a tiny pinhole which had worn in the bottom. Cleaned it up, sanded it and filled the area with some JB weld and left it on the bench for a couple of days. Repainted the filter and put it back on, no more leaks.
Old Feb 16, 2015 | 01:38 PM
  #28
Tedster9's Avatar
Tedster9
It seems to me it's caused by short trips, where things don't get up to temperature and results in condensation collecting inside the oil bath reservoir.
Old Feb 16, 2015 | 01:54 PM
  #29
Harrier's Avatar
Harrier
Great info guys, since my truck doesn't run much I haven't put any oil in the filter. I thought I has best do that, so it's sitting on the garage floor with oil in it waiting to see if there are any leaks.
Jay, show us some pictures of you engine and underneath. We love pictures. I'm glad you have decided to leave it together and drive it a bit. You will get a lot more enjoyment out of it that way.
Old Feb 17, 2015 | 12:14 PM
  #30
pbsdaddy's Avatar
pbsdaddy
Nice find. I think you may want to reconsider on the "R". I recall, several years ago, there was an article in all the newspapers, about a F O D D vehicle that made it off the assembly line, to the dealer and then sold. Very rare indeed!
