I see the solutions are being worked out, and my input isnt really necessary, but hooooooly hell that is an awful lift. that many springs!?!?!? someone must have really hated their spine when they went with a dozen leafed pack.
only need a couple inches of lift to clear 37's, do the rsk, find some good springs (plenty of suggestions) that don't have arc akin to the famous st lous arch, and use the shackle to adjust ride height to match. keep in mind, the factory f350 springs look very dinky, are virtually flat, and have decent ride quality.
I wonder if that truck had a big heavy plow on the front at one time. I doubt it but we put some helper springs on a buddy of mines truck to hold the plow in the winter. Just a thought.
because they think tall is cool. i saw one yesterday, 12 inch spring lift with 35 inch tires. the bottom of the truck was a good 8 inches above the top of the tires.
You can lose a spring or two and arc them up so you don't lose any lift, or the shackle lift as previously stated. I used to work in a spring shop and have done this a bit
