Engine orffset question....
Old Feb 9, 2015 | 08:52 PM
mustangmike6996's Avatar
mustangmike6996
I narrowed my CV IFS for my 1951 F1 2.75". I set the block in today and it seems to look and fit correct in the frame rails offset to the passenger side by about 1 inch. I figure this will give me enough "play room" to get the header and steering shaft on the driver side. What is everyone doing for engine offset?
Old Feb 9, 2015 | 10:29 PM
dmack91's Avatar
dmack91
Yours is quite a bit different than my set up, but I will add my 2 cents worth. I am running a 289 with stock exhaust manifolds, C4, Toyota PS, and stock front axle. I centered mine in the frame, but if I had to do it over again, I would have moved it about 1" to the passenger side. That would have made the steering box to exhaust manifold clearance much easier.
Old Feb 9, 2015 | 10:32 PM
mustangmike6996
Glad to hear I'm not insane for thinking this. The offset in the firewall favors the right side by about 1" too
Old Feb 10, 2015 | 04:18 AM
carnut122's Avatar
carnut122
I believe a 9" rear is offset too (at least it looks that way). I don't remember to what side, so you might want to check it out in case you go with a 9".
Old Feb 10, 2015 | 06:26 AM
49willard's Avatar
49willard
I did the same with a sbc but should have offset by 1" toward the passengers side.
Old Feb 10, 2015 | 07:42 AM
drptop70ss's Avatar
drptop70ss
Offsetting the engine to the side is fine as long as the trans is offset as well, that is keep the imaginary line from the front of the crank shaft through the trans tail shaft parallel with the frame rails. Doesn't matter where the pinion is as long as it is also parallel to the rails which it naturally should be, the driveshaft can be at an angle as long as the driveline angles are parallel.
Many 1960s big bolck factory cars had the engine offset from the factory to help with fitment issues around the steering box.
Old Feb 10, 2015 | 08:17 AM
mustangmike6996
Thanks guys. As stated above, it looks great offset by 1". I will be using a 8.8" which is offset as well. I do know, as long as the the front pinion angle and the rear pinion angle match each other in degrees it will not bind.
Old Feb 10, 2015 | 08:56 AM
GreatNorthWoods's Avatar
GreatNorthWoods
I offset my 302 two inches to the passenger side in my 49 F-1 since I used a Chrysler T-bar suspension. Worked fine.
Old Feb 10, 2015 | 04:04 PM
BlueOvalRage's Avatar
BlueOvalRage
One last consideration here - it is often actually beneficial to have the powertrain offset to the right side from a handling perspective. This helps balance the weight of the driver and the steering/braking/instrumentation equipment that is always hung on the left side of the vehicle. Figuring out exactly how much would require a bunch of math and complex calculations, but every little bit helps.
Old Feb 11, 2015 | 08:27 AM
mustangmike6996
Thanks. I dont plan on autocrossing it. I am more concerned about getting everything to fit with minimal mods to the truck itself. It looks like based on the headers (long tube BBK) and the top frame mounts, I will be a little closer to center than I originally thought. I will be maybe .5" offset to the right or less to avoid hitting the headers on the frame rail when the engine revs.
Old Feb 11, 2015 | 08:43 AM
mustangmike6996
Old Feb 11, 2015 | 08:44 AM
mustangmike6996
ChuckRob
23
Jun 22, 2012 09:57 PM
dewmillman
Feb 2, 2012 04:59 PM
OzFTrucker
Jul 12, 2006 02:13 AM
chan
Jan 7, 2004 10:18 AM
irondragon79
Oct 8, 2002 08:24 PM
