that is because a cummings is a gold plated wonder that gets 145 mpg while making 3000 hp after putting a K&N filter on it, a big "C" sticker on the back window, a 12 inch stack through the bed, and turning up the fuel until the exhaust will black out an intersection.
LMAO... I just spilled my beer over this!
Originally Posted by broncoderek
I mean, if you need one for towing, you're starting with the wrong gvwr truck anyway.
I agree with 4bt, and is always my advice for a 1/2 ton...
25+mpg (30 mpg with 1/2 ton running gear is possible), 600 lb/ft of torque with little to no money spent on mods, and the engine can be sourced for dirt cheap if you are resourceful. you don't need to buy a 5k hunk of junk engine off of ebay or craigslist...
in all honesty, swaps can be done for less than the cost of a 351 rebuild with normal cheap mods. you can pay 6k on a 351 or a 302 also...
I did mine for about 3k, which includes an nv5600, mounts, fluids, radiator, and other nickel and dimers. I was going to cut up a bread truck originally, but struck gold finding one in the jy. got it for 300 bucks complete, bought injectors, did some pump work, ported everything, regasketed; all for ~1500.
im a fan of all things that are nice, 300 and 351 included...but there is no comparison between in driving experience between a 300 hp 4bt vs any 300 hp gasser...much less something that has far less hp. combine that driving experience with phenomenal mileage, and no other reasons are necessary.
I don't see whats so wrong with a diesel swap. All the big trucks use diesel so why not make something different, F-150 diesel. I will say the F-150 frame is only 1/8 thick while the F-250/F-350 frame is 1/4 thick while the F Superduty frame is damn near 3/8 thick.
