Axle Tag # ???
Old Jul 22, 2003 | 02:55 PM
tcook487's Avatar
tcook487
Axle Tag # ???
I crawled under the truck and cleaned off the Axle Tag - now I just need to make sense of it...
VI 69 C ???
Also, has another sequence of numbers -
10 10 2 0E 11 ????
The Door Tag has D5 for the Axle Code?
The truck is a 90 F350 XLT Lariat - DRW
Any assistance would be much appreciated...
Thanks...
Old Jul 22, 2003 | 03:33 PM
jbalestri's Avatar
jbalestri
Axle Tag # ???
It looks like 4.10 gears. The bottom row starts with the gear ratio and the first number is usually hidden under the bolt. IE it should be 4 10 10 2 OE 11.
I don't remember my code exactly. If it was a limited slip, the first 4 digits would be 4L10. Double check, but I think you have open diff. I don't have my truck here to check, or I could verify that for you.
The stuff after the 4 10 is the month, day, year, shift kind of production stuff.
Old Jul 24, 2003 | 12:59 PM
steve83's Avatar
steve83
Axle Tag # ???
The "...10 2..." is the ring gear size: 10.25" (Sterling axle).
