starter problems
Old Feb 9, 2015 | 06:12 PM
ladelld33's Avatar
ladelld33
starter problems
so when i go to start my 84 f150 it makes this grinding noise the starter drags and its very hard to start. I've replaced the starter, flywheel, torque converter, & the ignition control module. the battery was changed too! i'm not sure what to do now. should i adjust the timing or what?????
Old Feb 9, 2015 | 06:16 PM
ladelld33's Avatar
ladelld33
i forgot to mention it's has a mildly built 351w with a c5 tranny & stock ignition! it came with the Ignition control module that has the blue grommet but i was told to try the yellow one so that's on it now
Old Feb 9, 2015 | 09:26 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Are you at high altitude???
Where do you connect the extra plug of the dual mode ignition module?
I would go back to the blue DSII module.
Where is your ignition timing set?
Have you confirmed TDC #1?
How many teeth are on your new flexplate?
Old Feb 10, 2015 | 08:43 AM
ladelld33's Avatar
ladelld33
the truck was doing just fine until i had the transmission rebuilt. the timing is at 10 degrees the flex-plate is a 164 the other plug is not connected. I'm in Charleston SC. so i call the store where i i got the starter from and he said that i need a shim on it. from what i've been seeing so far theses new aftermarket starters are needing to be shimmed. i've never heard of putting a shim on a ford ever....but its only $5 so its worth a shot i think...oh and i am gonna put the blue module back on the truck..
Old Feb 10, 2015 | 05:22 PM
BarG's Avatar
BarG
This may sound wierd but did you have your new starter tested before installing. I have had alternators brand new defective replaced with new defective and go back and find they had a bad lot. I always have my new parts tested now when possible.
Old Feb 10, 2015 | 07:58 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
How does a Ford starter shim work?
They bolt axially, not radially like a GM product.
Old Feb 11, 2015 | 01:27 PM
ladelld33's Avatar
ladelld33
yes i did make them check it before i bought it as i do now with all the new stuff that i buy. the guy at the store told me that these starters need to be shimmed now. i didn't have any of these issues with the 302 that was in the truck because it had the original starter on it so i thought that it would be a good idea to replace it with a new one since i went with a 351w i really wish i knew where my engine builder put that old starter.. so i'm gonna give the shim a try since it was only $8 and it is just for a ford starter too!!!!
Old Mar 30, 2015 | 05:51 PM
ladelld33's Avatar
ladelld33
so i installed that damn shim it took a minute but i got it in. the truck started fine for a few days but it's back to the old grinding again. now I'm trying to figure out what to do. i'm thinking about going to a manual transmission any thoughts???????
Old Apr 5, 2015 | 06:51 PM
ladelld33's Avatar
ladelld33
well i guess that this one has everyone stumped so i'm gonna take it to an electrical shop to se what they can find out what they can find out.
Old Apr 6, 2015 | 06:23 AM
trevisM's Avatar
trevisM
If the spacer/index plate is bent it can cause the starter to be misaligned, also I have had replacement starters that could move/rotate a small amount on the bolts; just enough to cause partial engagement of the pinion and ring. When installing the starter you might try to push/rotate it toward the engine as you tighten the bolts. Or away.
If they told me the starter needed a shim on a Ford, I would simply get my money back and go elsewhere, if it's manufactured wrong and they know it they should not sell it.
Old Apr 6, 2015 | 09:48 AM
LARIAT 85's Avatar
LARIAT 85
I had a similar problem like that once and it turned out to be a bad ground wire connection.
Check where the negative battery cable bolts (grounds) to the front of the engine. If you see any corrosion there, clean it off real good and re-connect the cable. And check both battery cables and your starter cable for wear.
Old Apr 6, 2015 | 06:30 PM
ladelld33's Avatar
ladelld33
Thanks i'll give that ground cable another look also i did notice the engine plate was bent so I'm guessing i should just get a new one instead of trying to straighten tht one right!!!
Old Apr 6, 2015 | 08:34 PM
trevisM's Avatar
trevisM
I've just slid a flat bar or such between bell housing and spacer and hammered flat, easier than pulling transmission.
Only two contact points really on these starters and can be a bit like a seesaw, the index plate kinda keeps the starter perpendicular to the flexplate. I'd not give much chance of finding a new one.
Old Apr 14, 2015 | 09:40 AM
ladelld33's Avatar
ladelld33
i ordered a high torque starter which hasn't come in yet cleaned all connenections so hopefully this weekend i'll see how this new starter works. my engine builder just told me that the oe starter wont work well with an engine with over 10:1 compression. that would have been great to know a long time ago right!!!
Old Apr 20, 2015 | 07:23 AM
ladelld33's Avatar
ladelld33
UPDATE
so i installed the high torque starter this weekend without te spacer put in the new heavey duty silenliond and new plugs cleaned all the connections and it started like a ford should when i was finished. no i haven't road tested her yet due to bad weather yesterday and i need to instal the heat sheild for the starter but, so far it's starting great.
