Speedometer stopped working?
Old Feb 9, 2015 | 05:19 PM
74 F350 SCS's Avatar
74 F350 SCS
Howdy- the speedometer on my 74 F350 with 460 and C6 stopped working. The cable has not been tampered with and appears to be securely fastened at the tranny and speedo cluster. It does not vibrate or bounce nor any noise, nothing at all. It operated perfectly and smoothly prior. All other instrument gauges and lighting work just fine. I assume the speedometer is purely mechanical and no electronics are involved. Any assistance of what to look for is appreciated.
Old Feb 9, 2015 | 05:31 PM
raytasch's Avatar
raytasch
Believe Nothing
Most common problem is with the cable. Have you pulled the cable loose at the head or or at the transmission to see if the internal is good? Yes, the speedometer is pure mechanical.
Old Feb 9, 2015 | 05:53 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Pull one end or the other and see if the cable is broken, take off the trans side and put a cordless drill on it....I have heard that works anyway?
Old Feb 10, 2015 | 06:35 PM
74 F350 SCS
Much obliged to the both of you for your advice. I will disconnect and inspect then reconnect. The diagrams are also very helpful. Thanks!
eatont9999
16
Dec 9, 2011 09:29 PM
rashanny
24
Mar 31, 2011 11:14 PM
72sportcustom3906.4l
Jun 20, 2009 05:56 AM
Dustin_86
Nov 1, 2004 10:17 PM
GammaDriver
Jul 4, 2002 09:59 AM
