400 Power?
Old Jul 25, 2003 | 11:06 AM
GT40man's Avatar
GT40man
400 Power?
well thats gonna drop the figures a bit, guess i have to redo it. i guess i misunderstood.
Old Jul 25, 2003 | 11:36 AM
77highboy's Avatar
77highboy
400 Power?
what changs the figures?....the cam being hyd not solid? if so the what does it take to make it a solid?......new cam and lifters?....just lifters?.........as you can tell i know nothing about cams
Old Jul 25, 2003 | 11:50 AM
bubbaf250's Avatar
bubbaf250
400 Power?
Cams are designed for either solid or hydraulic lifters, so you have to change the cam and the lifters to switch the lifter type.
You really don't want solid lifters unless you need very high rpm (6K+) power, and you're willing to make valve lash adjustment a routine part of your maintenance procedure.
If you want more power than that Lunati cam can give, you should consider a different dual-pattern (hydraulic) cam with more lift on the exhaust valve.
oldmansimek
Feb 12, 2010 07:53 AM
nebechanezer
Mar 5, 2005 09:09 PM
uemf
15
Oct 6, 2004 07:36 AM
Redone
Feb 7, 2004 08:29 PM
