Specified Torque Settings 1995 F-150
Old Mar 26, 2002 | 08:21 PM
TexasGuy001's Avatar
TexasGuy001
Does any one know what the torque specs are for that bolts that hold the drive shaft to the rear differential?? It doesn't have U-bolts. There are four bolts. Thanks for any input.
Old Mar 26, 2002 | 11:09 PM
PAUL_2's Avatar
PAUL_2
If you can post your trucks specifics , Engine , trans , 2 or 4WD I can look it up .
Old Mar 27, 2002 | 02:51 AM
TexasGuy001
Its a 1995 F-150 5.0 302 AODE 2WD. Its also a long bed regular cab. I don't know if that makes a difference but some of the trucks have different driveshafts. It has an aluminum one.
Old Mar 27, 2002 | 09:52 AM
PAUL_2's Avatar
PAUL_2
Old Mar 27, 2002 | 10:02 AM
PAUL_2's Avatar
PAUL_2
It says 70 to 95 Ft Lbs , But it also says that only the E Series vans have the circular flange . Then again Im pretty sure I have seen the trucks use the circular flange .
Old Mar 28, 2002 | 02:21 AM
TexasGuy001
Thanks for looking it up for me
dieselbronc
Mar 4, 2021 10:10 PM
cutlass
Jul 15, 2012 11:16 AM
Striderwv
Sep 28, 2011 09:16 AM
fluidp
Jun 28, 2008 02:56 PM
xuare
Dec 15, 2002 03:09 PM
