AC rebuild/refresh
I crawled under last night to explore the Ac clutch air gap and found that the shaft seal is leaking and clutch is grooved pretty bad and covered in oil.
I'm thinking it's time for a compressor, clutch, orifice tube, expansion valve and reciever/dryer. Does that about sum it up? I haven't messed with AC systems much outside of my simple jeep system that was as easy as two seals and recharge in my garage to fix it.
Do I need to flush the lines out? Should I do that at all? Motor craft worth the cost over something like four seasons? Its almost twice the cost but in the end if something goes I'm further downstream after freon etc to charge it and the possible shop charge if I pay to have to done.
Anyone done this whole deal yet?
The cheapest/easiest way is to replace the compressor, orifice tube and the accumulator and not flush the lines. After the installation is complete you would run the system on vacuum, check for leaks and then recharge.
The best way will certainly cost a bit more but will be the best approach for the long term. Remove the compressor, orifice tube, accumulator, condenser and the rear lines at the evaporator. Flush the lines with something like Fast Flush and blow out any residue. Install the new compressor, orifice tube, accumulator and a new condenser. Then pull vacuum and recharge. This method will provide the best efficiency but will certainly cost more for the parts and the amount of time it will take to complete the work.
Anything specific about flushing the lines? Can you flush a condenser?
