Dos FICMs - Contribution code
Old Feb 8, 2015 | 09:01 PM
brown89ford's Avatar
brown89ford
I was not expecting this to happen, I am getting a contribution code on #4.
Scanned and cleared with TorquePro.
Problem went away ONCE on the drive to getting it emission tested. Got lucky with that.
Bought hot shot secret. Drove it. Some minor change is throttle response probably VGT getting cleaned up.
Replaced injector - code continues, but the "roughness" did change a little.
Swapped FICM, in the driveway first start no code. Cool!
Drove it around and about five miles into the drive at a light...the elusive contribution code for #4 returned.
I would have thought this contribution code would have been thrown if there was a hard failure in the injector (spool valve hang). I would have thought a Low/High circuit code would be thrown in this case...
So is this an intermittent harness failure??? I guess technically it is possible but want a little confirmation from the Pros here.
Old Feb 8, 2015 | 09:35 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
What year engine?
Easiest test is to swap injectors with another cylinder and see if the issue remains or follows injector.
Beyond that, inspect all connector pins.
Bubble test that cylinder bank.
Fuel in oil? May have to do an oil drain and do a fuel in oil test.
After that suspect hard part failure, bent pushrod or failing lifter.
Josh
Old Feb 8, 2015 | 09:39 PM
brown89ford
Originally Posted by Bullitt390
What year engine?
Josh
2004 XLT with 2005 reman engine. (date on FICM was Feb 2014)
Injector already swapped, FICM already swapped, no fuel in oil. no oil in coolant.
Lifter failure...didn't think about that. Hmm.
Ill check the connector and go from there.
Old Feb 8, 2015 | 10:09 PM
brown89ford
I Just started the engine again, it was already warm and it was throwing the contribution code before I shut it off. Upon start everything was smooth. I cleared the codes and re-scanned. All good. I then did my best to wiggle out the harness to force the code to return. Nothing. All is good. So, maybe it is a lifter. Then engines prior life as Im told was in a service truck, the oil in the bottom of the pan was sludge like...so maybe the lifter is acting up because of the oil/hot shot secret? The lifter may be partially stuck down (collapsed) and is working loose? I would get the contribution code on cold start as well.
Still scratching my head on this. The lifter theory seems like it is valid since the contribution code is somewhat intermittent. Could still be a harness if some capacitance or other transient electrical effect is cause by a failing harness. The harness looks great though. No visible damage/wear. I didn't get into look at the socket/pins yet.
I need to look up the bubble test. Im not familiar with that.
Old Feb 8, 2015 | 10:25 PM
Bullitt390's Avatar
Bullitt390
Ford IDS would help take a lot of guesswork out. Run a contribution test and dynamic compression test.
For hard part failure you would work your way down starting with the rocker arm, pushrod and then lifter.
Josh
Old Feb 9, 2015 | 05:57 AM
jsm180's Avatar
jsm180
It's a long shot but the only other links in the chain are the crankshaft and cam sensors, hard to believe they could cause an issue on the same cyl every time but Murphy doesn't play fair.
Old Feb 11, 2015 | 09:21 PM
brown89ford
So now ...... about three descent runs and not one hiccup or code thrown?
Still a mystery, but don't care if it goes away and stays away.
nashvegas99
Feb 12, 2017 06:41 PM
jstihl
May 27, 2016 06:30 AM
kt19
Oct 27, 2014 05:37 PM
btsb032304
Sep 3, 2010 07:22 PM
Pastmaster
Jan 2, 2003 05:53 PM
