I have a 1995 F150 4X4 and would like to upgrade to a Ford 10.25" or 10.50" rearend when I put a solid front axle under the front. Do the Rear Wheel Speed Sensor Rings have the same ratio or can I get a computer fron a 3/4 or 1 ton with a 351/Auto like I have?
The speed ring is bigger on the 10.25.
I changed mine to the 10.25, I was running 35's so it actually brought the speedo closer to actual.
You don't need to change the computer, You reprogram the speedometer, there's instruction on how to do that on this site.
Good luck
Aaron
