Boot replaceable?
Old Feb 6, 2015 | 08:03 PM
USMC1968's Avatar
USMC1968
Boot replaceable?
All,
While mucking around the engine compartment cleaning it I looked down and noticed a grease boot had ruptured at a link. Is it possible to replace the boot alone or do I have to replace the whole link? Is that an inner tie rod (that would need to be replaced?) It is on the drivers side of a 2000 F250 SD CC 7.3 4x2. I think the link on the right of the top picture is called a Pitman arm?
This summer I am going to scrape it all down and spray with Rust neutralizer and paint!
Thanks in advance,
Semper Fi
Old Feb 6, 2015 | 09:03 PM
F350-6's Avatar
F350-6
If you can find one you can replace it. Not sure where you'd find one though. Might be better off with some sort of flexible tape around it or just keeping it pumped full of grease.
Semper Fi.
Old Feb 6, 2015 | 09:30 PM
BadDogKuzz's Avatar
BadDogKuzz
Like Chris said you might having a hard time finding a new one. You might be able to find a good boot off a bad inner tie rod that someone has replaced. Now are you sure that inner tie rod isn't going bad ?
Old Feb 7, 2015 | 12:24 AM
Kamstutz's Avatar
Kamstutz
Keep greased until it goes bad. I have seen these last a long time this way IF you keep them greased.
Old Feb 7, 2015 | 07:21 AM
USMC1968's Avatar
USMC1968
Ok, cool thanks all for the replies. No, it is solid the tie rod does not move (except rotate because it is on a ball joint). I will leave it alone and keep it lubed!
Semper Fi
Old Feb 7, 2015 | 07:35 AM
bigb56's Avatar
bigb56
I bought some aftermarket grease boots from AutoZone, can't remember the brand but they were bright red. I replaced one on my drag link. You do have to separate the link to install. The red boots are great, thick and tough. If I find the package with the remaining boot out there in my garage somewhere I will post back.
Old Feb 7, 2015 | 09:30 AM
rcgtsport's Avatar
rcgtsport
red boots most likely energy suspension. they make them in black also.
Old Feb 7, 2015 | 03:43 PM
truckeemtnfords's Avatar
truckeemtnfords
Veteran: Marine Corps
I was also going to recommend energy suspension, I have used there black ones on several vehicles. They are polyurethane and hold up excellent.
Old Feb 7, 2015 | 04:35 PM
David7.3's Avatar
David7.3
Originally Posted by USMC1968
All,
Thanks in advance,
Semper Fi
The pitman arm bolts to the steering box, the drag link bolts to the pitman arm, your boot is the left inner tierod end. and off course you have 2 outer tierod ends, the boots dont really seal they just compress, so over greasing can push the grease out, if you keep it greased you should have no problem, just wipe the mess up, or when your working under there it will be in your hair.
Aussie BrianB
Australia Chapter
30
Jun 28, 2017 07:43 PM
benbuilder
Dec 29, 2016 11:48 PM
Quazz209
Jun 26, 2009 02:32 PM
Joe_D
Apr 29, 2008 09:56 AM
