SAS, Lift and Towing dillemma
I acquired all of the goods needed to convert my 97 F250 from IFS to SAS. The source vehicle is a 97 F350. The issue is that the F350 has a Rough Country 4" lift kit installed and I'm not really sold on the idea of having a lift kit. I tow regularly, sometimes scaling at 20-22k but usually much less. The truck is completely stock and tows great, even with the 3:55 gears.
With the SAS will I gain any height or is just level out, I'm wondering if the SAS and lift will be 4 inches or closer to 6? I think the rear lift is just has 3" blocks with replacement springs in the front.
Option 1: Install what I have and probably go to 285/75-16 tires since they are slightly taller but 2" wider than stock (I have 9x16 wheels). Probably still look bad if total lift is 5-6".
Option 2: Source all the parts to make it a stock F350. Pitman arm, springs, what else? Can I use the F250 u-bolts with the F350 springs?
What are your experiences? Have other options?
Thanks,
Bob
Thanks,
Bob
NONE of my f350s or f250 with dana 60s ever rode this ruff. the ride SUCKS
on
1 Post
You need the F350 pitman arm, the driver's side lower U bolt cast bracket and the track bar bracket that mounts under the oil pan to the frame cross member, and the track bar itself.
Your brake calipers will attach to the donor axle as they are the same '95 and newer style, so you don't have to break open your brake system.
You DO need the F350 drag link and steering tie rod set up. The F250 setup is different and not as beefy.
Source some F350 OBS front leaf springs from a local junkyard. Even if they are clapped out and sagging. It's a better place to start than a 4" spring lift or using the IFS leafs.
Yes, the official recommendation is to never reuse U bolts. I am using the same factory U bolts from the F250 IFS on the F350 SAS set up.
f100beatertruck
09-21-2013 06:51 PM
renegade_75
04-02-2013 11:35 AM
sju96ford
20
03-29-2012 07:57 PM
DJdemon6696
06-30-2008 11:47 PM
