I'm running the 91-93 intercooled radiator, if anything it runs too cool. The desert cool would be way too much capacity and would take up too much room as well. With the much thinner radiator I am running now, that is as close as I can comfortably get to the radiator support. I only have 3/4" between the fan clutch and radiator.
I'm not worried about it fitting because I already got the desert cool I had in it to fit. Clears the fan and everything. Just worried about cooling
co425 is running the same one I am. I tried the desert cooler way to big lots of problems making it fit with 99 ford intercooler that I used.Had a little problem with heat at first then s#!t canned the electric fans and used a ford 400 fan and cummins clutch,heat gone!
