Sponsored by: Real Truck
Spark plug replacement on a 6.2
Old Feb 5, 2015 | 12:32 PM
jeb79's Avatar
jeb79
I'm nearing 100K on my 2011 F250 6.2 and I was planning to change the plugs pretty soon. I was just wondering if anyone has done this themselves on this motor. If so, any tips, things to look out for, etc.? I realize there are 16. I've always changed them with no problem on my 2v 5.4 super duty.
Old Feb 6, 2015 | 12:43 PM
droldsmorland's Avatar
droldsmorland
Subscribing. Also what plugs would the masses recommend?
Old Feb 10, 2015 | 11:16 AM
ccerniglia's Avatar
ccerniglia
Not a lot available aftermarket for the plugs. If you want stock get the Motorcraft SP526(Double platnium tip). If you want a better performing plug I would use Denso ITV20's (Iridium fine wire) and change them every 50K at least.
As for R&R of the plugs, pretty straight forward. Plug gap is 0.042-0.046 in and plugs should be torqued to 18lb-ft.
Old May 30, 2015 | 11:46 AM
StewB's Avatar
StewB
Has anyone got a procedure for this? Looking at doing a spark plug change on my 2011 f350. looking for any tips and tricks. Truck has 93,000 km so figure it's time. Local dealer wants $650.00 parts and labour so am going to tackle this myself.
Thanks for any input
Stew
Old May 31, 2015 | 12:01 AM
BigT_KY's Avatar
BigT_KY
Interested in this as well
Old May 31, 2015 | 05:39 AM
Just Strokin's Avatar
Just Strokin
From Ford 2014 Service DVD for 6.2L Spark Plugs
Ignition Coil-On-Plug
Material Item Specification
Silicone Brake Caliper Grease and Dielectric Compound
XG-3-A ESE-M1C171-A
Removal and Installation
Remove the Air Cleaner (ACL) outlet pipe.
Remove the intake air resonator.
Disconnect the 8 ignition wires.
Disconnect the 8 ignition coil-on-plug electrical connectors.
Remove the 8 ignition coil-on-plug bolts.
To install, tighten to 10 Nm (89 lb-in).
NOTE: When removing the ignition coil-on-plugs, a slight twisting motion will break the seal and ease removal.
Remove the 8 ignition coil-on-plugs.
NOTE: Verify that the ignition coil spring is correctly located inside the ignition coil-on-plug boot and that there is no damage to the tip of the boot.
To install, reverse the removal procedure.
Apply a light coat of dielectric compound to the inside of the ignition coil boots.
Spark Plugs
Removal
NOTICE: The spark plug procedure must be followed exactly or damage to the cylinder head and spark plug will result.
NOTICE: Do not remove the spark plugs when the engine is hot or cold soaked. Spark plug thread or cylinder head damage can occur. Make sure the engine is warm (hand touch after cooling down) prior to spark plug removal.
Upper spark plugs
Remove the ignition coil-on-plugs. For additional information, refer to Ignition Coil-On-Plug.
Lower spark plugs
Disconnect the ignition wire from the lower spark plugs.
All spark plugs
NOTICE: Only use hand tools when removing or installing the spark plugs or damage can occur to the cylinder head or spark plug.
NOTE: Use compressed air to remove any foreign material from the spark plug well before removing the spark plugs.
Remove the spark plugs.
Inspect the spark plugs.
Installation
All spark plugs
Adjust the spark plug gaps as necessary. For the correct spark plug gap specification, refer to Specifications in this section.
Install the spark plugs.
Tighten to 18 Nm (159 lb-in).
Lower spark plugs
Connect the ignition wire to the lower spark plugs.
Upper spark plugs
Install the ignition coil-on-plugs.
Old May 31, 2015 | 09:08 AM
scraprat's Avatar
scraprat
Top Answer: 5
Larry,
Thanks for the 6.2 info
Old May 31, 2015 | 09:33 AM
StewB's Avatar
StewB
Thanks for the procedure.
Old May 31, 2015 | 10:08 AM
minke's Avatar
minke
What is hot soaked or cold soaked??
thanks,,,
Old Jun 1, 2015 | 08:55 AM
droldsmorland
Anyone have spark plug brand and part numbers recommendations??? Never mind I see I posted this very Q back in Feb.
Old Jun 1, 2015 | 02:16 PM
sammy77's Avatar
sammy77
I would highly recommend sticking with Motorcraft.
Old Jun 1, 2015 | 02:45 PM
Gangly's Avatar
Gangly
thanks,,,
Means fully warmed (still hot after driving) or fully cooled(sat for an hour after driving).
You want to change the plugs when the heads are slightly warm to the touch but not so much as to be uncomfortable.
Old Jun 1, 2015 | 03:33 PM
minke's Avatar
minke
Thank you Gangly.
Old Jun 1, 2015 | 06:16 PM
Just Strokin
thanks,,,
Cold soaked would also mean overnight or for any extended period of time beyond a few hours after vehicle was last operated....I would warm the truck up for 4-5 minutes and then let cool some before removing the plugs.
Old Jun 1, 2015 | 11:27 PM
droldsmorland
How about a dab of anti-seize on each plug before installation; or at min a dab of 30w oil. I typically practice one or the other depending on the engine. Is this recommend with the 6.2???
