Fuel pump
Old Feb 4, 2015 | 07:12 PM
Shane Carruth's Avatar
Shane Carruth
Fuel pump
What type of fuel pump is this and where can I get a replacement. None of the replacement fuel pumps look like this.
1965 Ford F100
Inline 6 4.9L
Old Feb 5, 2015 | 11:33 AM
TA455HO's Avatar
TA455HO
Lead Gopher
1965 Ford F100
Inline 6 4.9L
I don't think that's the original style fuel pump as it should have had a built-in filter canister. Napa online shows a pump like what I think of as more stock appearing when I choose 1965 F100 4.9L
NAPA AUTO PARTS
If I instead choose 1980 F100 4.9L then it shows a pump more like what you have there.
NAPA AUTO PARTS
If you run a pump like this I think you'd want a separate fuel filter in-line to capture any crud. Otherwise probably doesn't matter as far as function goes.
Old Feb 6, 2015 | 09:34 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The fuel pump is from a 1978/85 300 I-6. Here's a pic (lower) of the original. Inside the canister is a corrugated paper cartridge fuel filter
If the carb is also from a 1978/85, the fuel filter threads into the front of it.
But if the carb is the original, the fuel filter (if it has one) used with this 1978 and later pump, would be an in-line type, spliced into the fuel line by a previous owner.
hermancm
May 10, 2014 10:50 PM
abe
Jul 21, 2013 10:13 AM
r23k4u1968
Aug 27, 2010 06:24 PM
Michigan Rick
May 29, 2010 11:32 AM
wizardbee
Aug 19, 2003 05:23 PM
