Auxiliary Leaf Springs
Old Feb 4, 2015 | 12:39 PM
whodat_ford's Avatar
whodat_ford
Has anybody mounted the auxiliary leaf springs that the Super Duties with the camper package have? They are the springs on top of the main leaf pack and have significantly more arch. There are also pads that mount to the side of the frame the act as a jounce bumper to the spring.
I do not want airbags because of having to inflate them all the time, and I do not want to install on board air.
Thanks!
Old Feb 4, 2015 | 09:05 PM
tbear853's Avatar
tbear853
I've had them in the past, they do add unsprung weight and they are always "there". If hauling heavy is a constant thing, you might like them. When unloaded and they just are weight they do add more weight bouncing with the axle for the shocks to control. I now prefer the air if anything but I seldom haul heavy enough to benefit from them on my trucks, but I do use the Air Lifts on my Merc occasionally, they don't loose air and I like the adjustability. If I did haul heavy enough often enough to make me want to add the aux. leaf spring packs like on a F250 or F350 ..... I'ld have a F250 or 350.
Old Feb 4, 2015 | 11:05 PM
whodat_ford
Thanks for the suggestions. My current leaf springs are just worn out. It might be better to add a leaf.
69 Crewcab
Dec 2, 2018 01:44 PM
radium
6.7L Power Stroke Diesel
60
Jun 15, 2016 07:33 PM
truckfella
May 6, 2013 11:34 AM
17witha664x4
Feb 3, 2012 03:22 PM
Carolina Sorillo
Nov 29, 2010 07:38 AM
