37s on!
Old Feb 4, 2015 | 06:43 PM
ponykilr's Avatar
ponykilr
Did you use your springs or Super Duty springs?
Originally Posted by ceetwarrior
Looks nice!! Love the cut front bumper, looks nice. I use washers and shim mine forward as much as I can on all my OBS trucks as I like chrome and don't want to cut any more than the corner off.
If you do a shackle reversal you'll be thrilled in ride quality difference, I was.
Old Feb 5, 2015 | 08:05 AM
ceetwarrior's Avatar
ceetwarrior
I just re used my stock springs. I didn't know about the super duty springs otherwise I would have used my 30k mile set I have laying around...
Three words, adjustable track bar......!
Old Feb 5, 2015 | 12:02 PM
rugermack's Avatar
rugermack
Looks great !! I would like to see the light bar
Old Feb 5, 2015 | 06:20 PM
ponykilr's Avatar
ponykilr
I have it bent, welded and painted. I will get it put on and take some pics to post. It is 1.25" x .120 wall HREW tube.
My first time using my tube bender for something that needs to be perfect. I am very proud of it, it looks good. It has room for two 6" lights.
I will be making tube full length sliders soon.
Old Feb 10, 2015 | 06:40 PM
Chrisrehpot's Avatar
Chrisrehpot
I like it! mine is lifted way to high but plan on getting new springs and dropping in to 4". Nice to know my 37" will fit if your tires are fitting fine. Nice truck.
Old Feb 10, 2015 | 07:11 PM
ponykilr's Avatar
ponykilr
Thanks
Old Feb 11, 2015 | 05:11 AM
Dialed-In's Avatar
Dialed-In
Originally Posted by WickdL
I agree. Im not into the lifted trucks. My fiberglass fenders allowed me to run 37x13.5. I did the opposite end though. I dropped the rear 2" by removing the factory blocks
Tony B.
I'm in the process of setting up my F-150 with a similar set-up to yours Tony. I'm removing the rear block too and am going to run some 38.5" TSL-SX tires on 10" wheels with the help of some Bushwacker cut-out flares (no lift).
For now it's running 35" MTR-Kevlars w/o any lift, just a front bumper trimming like Ponykilr did.
I too am a believer in a Low Center of Gravity, especially for 4x4's. By running 38" tires I'm gaining over 4 inches of lift and it's all gained at the axle where you need it the most.
Sweet looking Ford Ponykilr the grey wheels and black bumper/grill go well with the white paint, not to mention the large tires filling out the wheel wells nicely...
Cheers D
Old Feb 11, 2015 | 10:49 AM
ponykilr's Avatar
ponykilr
I just realized I promised to post pics of the light bar in this thread.
It is made to bolt on, not a push bar, just a light bar although it is .120 wall HREW.
Old Feb 11, 2015 | 03:22 PM
rugermack's Avatar
rugermack
Looks good, I'm thinking about something like that. I have tube for sliders already too. Have too much stuff I already started to finish first.
Old Mar 2, 2015 | 09:02 AM
Chrisrehpot
What is your offset on your wheels? With my tires turned hard it rubs my springs. Im hoping we have the same offset, that way it will get fixed when I correct my suspension.
Old Mar 2, 2015 | 11:23 AM
ponykilr's Avatar
ponykilr
My wheels are 8.25 wide (inside beads) and 3.5 backspace. The tires do not rub the spring.
Old Mar 2, 2015 | 01:56 PM
Chrisrehpot
That makes me happy, mine are 17x9 with a 4.5" backspacing. Thanks for the input.
SHOpar
6.7L Power Stroke Diesel
Feb 26, 2016 01:01 PM
schoo
13
Apr 23, 2014 08:41 PM
Ecoboost97
Ford Truck Parts for Sale
Jan 23, 2014 03:51 PM
