4 Wheel Drive
Old Feb 3, 2015 | 11:09 AM
Turtle6688's Avatar
Turtle6688
4 Wheel Drive
Well after all of the snow lately I figure my four wheel high and low doesn't work. I don't think it is the hubs not activating or anything because I hear hubs click In for high and low. I tried searching the forum for this issue but all I found was thing out the vacuum lines. Any ideas what this could be?
Old Feb 3, 2015 | 11:33 AM
Mr. Crab's Avatar
Mr. Crab
Don't think it's the hubs you are hearing; it's more likely the shift motor on the transfer case. Have you tried locking the hubs manually? Also, there a thread just recently about how to diagnose the vacuum lines, which would also cause hijinx with A/C.
Old Feb 3, 2015 | 11:35 AM
Turtle6688's Avatar
Turtle6688
I'll check out the hubs today. Even if the hubs are auto I can manually activate them? The PO told me they were auto.
Old Feb 3, 2015 | 01:00 PM
Mr. Crab's Avatar
Mr. Crab
You can lock manually by turning the hub center. They should only turn in one direction, which should lock them. To unlock, just turn back in the other direction. I don't think they are marked but haven't looked in a while.
Old Feb 3, 2015 | 02:59 PM
nmclella's Avatar
nmclella
Mr. Crab is correct Turtle. They are marked however (atleast on my 2004 EB), so you can see when they are locked/on auto.
Old Feb 3, 2015 | 04:24 PM
Turtle6688's Avatar
Turtle6688
Thanks guys, big help. I locked in the hubs earlier and 4x4 worked perfectly. Now the reason why it doesn't engage automatically has something to do with the vacuum?
Old Feb 3, 2015 | 05:30 PM
WE3ZS's Avatar
WE3ZS
Either vacuum or the hubs just need to be taken apart, cleaned, lubed and reassembled. Sometimes they just get gummed up and need a good cleaning/servicing to get them working again. Both vacuum troubleshooting and servicing them are covered in the Tech Folder at the top of this forum.
Good luck!
Old Feb 3, 2015 | 05:32 PM
Turtle6688's Avatar
Turtle6688
Good luck!
Ill have to try that when it warms up. Truck barely fits in the garage, height wise. Just ordered some ball joints so ill have to do them at the same time.
Thanks everyone for the help!
Old Feb 10, 2015 | 08:52 AM
Turtle6688's Avatar
Turtle6688
Well I checked the hubs the other day, the drivers side had some broken parts in it, and the passenger side was just fine. So I guess I'm going to buy a set of manual hubs. I was looking at Mile Marker, but they said they only fit a f250 and not an EX. I thought the parts were compatible, but I want to make sure before I spend the money.
Old Feb 10, 2015 | 10:38 AM
harley4jcs's Avatar
harley4jcs
http://www.ebay.com/itm/Mile-Marker-Mile-Marker-Supreme-Manual-Hub-449SS-/181542810702?pt=Motors_Car_Truck_Parts_Accessories&hash=item2a44cb744e&vxp=mtr
These are the one you want. You can find them for less if you are not in a big hurry. I've got them for $90 pair. They work & look great. Fitting all Dana 50 & 60 axels.
Old Feb 12, 2015 | 04:46 AM
Stewart_H's Avatar
Stewart_H
Maybe because it's late and i'm more than tired, but....
Stewart
lundman
6.7L Power Stroke Diesel
15
Jan 22, 2014 07:54 AM
millerl513
May 21, 2010 11:24 AM
shad9876
Mar 27, 2010 11:23 PM
2012 SD Snowbuster
Dec 15, 2006 09:50 AM
brmann
Aug 14, 2001 08:16 AM
