79 400m
Old Feb 2, 2015 | 08:37 PM
ernie79's Avatar
ernie79
79 400m
Dies when I put in gear I think it could be the modulator valve help please
Old Feb 2, 2015 | 09:15 PM
HIO Silver's Avatar
HIO Silver
And what led to that conclusion?
Outline the steps that have been taken thus far in troubleshooting?
Old Feb 3, 2015 | 09:11 PM
ernie79's Avatar
ernie79
steps
Set my carb blocked off all leaking vacuum replaced the distributor. Wires New coil and New msd box set timming at 13 advanced. And used water remover in the gas starts grate and will rev to the moon no missing
Old Feb 3, 2015 | 11:23 PM
tbear853's Avatar
tbear853
If you suspect a vacuum leak through the modulator valve, unplug the rubber tube leading to it and plug it off and try it. If it still dies, not a vacuum leak there.
I think your problem is carb related.
Old Feb 4, 2015 | 07:00 PM
ernie79's Avatar
ernie79
It did back fire through it I thought it might b a power valve it is a Holley
Old Feb 4, 2015 | 09:19 PM
tbear853's Avatar
tbear853
If it back fired and if it has a Holley that doesn't have either an anti back fire ball check valve or that hasn't been retrofitted with the anti back fire ball check valve in the base plate to main body joint, the violent pressure of a back fire through that vacuum feed port can easily blow a power valve's diaphragm. Only way I know to test it is to remove the power valve and apply vacuum to it and see if it closes against it's spring. A ruptured power valve will cause a rich condition.
Old Feb 4, 2015 | 09:36 PM
Tedster9's Avatar
Tedster9
Quick test to see if power valve is OK - the engine should stall when mixture screws are turned in all the way.
Old Feb 5, 2015 | 04:32 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
No such thing as a 400M, it's just plain 'ol 400.
If this truck has T/E (smog pump), it also has an anti backfire valve as it's part of the T/E (Thermactor Emission) system.
cgunning17
13
Sep 7, 2018 08:05 AM
expocell
Jul 18, 2013 06:16 AM
TheMech
Feb 20, 2006 12:17 PM
LTTLMAN
Feb 12, 2005 04:00 PM
