Sponsored by: Real Truck
5.4l engine swap questions
Old Feb 1, 2015 | 09:01 PM
tsw902's Avatar
tsw902
Ok so recently I flooded my 2000 xlt. Long story short, she sucked water and ended up throwing a rod through the oil pan and cylinder wall (just my luck)...
So we've gotten the truck back from insurance and they totaled it. We kept the truck and plan on putting a new engine in it with the payoff. Were also gonna buy a 2003 xlt extended cab with a bad motor for 300$ (not bad, it needs work though)
My main question is, can I swap a 2v 5.4l v8 for a 3v 5.4 (and vise verses), without having to change computers and all?
I know the 3v blow plugs and all. But I would like to get the little boost of performance the 3v offers. (I can get a remanufactured 3v with improved plug holes).
Old Feb 1, 2015 | 09:12 PM
Toxic2's Avatar
Toxic2
from what i gather you are better off sticking with a 2v..too much hassel to put a 3v in place of a 2v..and yes you need to swap all electrical and computer
Old Feb 1, 2015 | 09:24 PM
tsw902's Avatar
tsw902
Really? That sucks. Would the harness from a 2v work with a 3v? I can get computers at a decent price.
Old Feb 2, 2015 | 01:46 AM
Mike189677's Avatar
Mike189677
Actually it's the early 2 valves that had problems blowing plugs they added more threads to the heads at some point in 02. The 3 valves had a problem with the plugs breaking off in the head when your trying to change them. They were 2 piece design originally then updated to a one piece plug midway through 08. If you wanted a performance boost you could swap in a 2 valve v10 and it would out perform a 3 valve 5.4. you would still need a computer,wiring, harness, a v10 radiator and either a v10 transmission or have your trans upgraded to the v10 specs. You would be best served to find a donor truck that was wrecked that way you have every thing you need right there. Or you could just put gears in you truck after you put a new or rebuilt 5.4 in it. 4.30's seem to be the sweet spot to stock size tires.
bignast1
Jan 8, 2016 01:55 PM
sedrick38
Mar 27, 2009 11:51 PM
Lovemyfords
Nov 21, 2007 10:15 PM
les1cam
Engine Swaps
Jan 15, 2006 08:16 PM
Hubbard Place
Sep 28, 2005 09:18 PM
