Headlights staying on
Old Feb 1, 2015 | 02:51 PM
sudsmcduff's Avatar
sudsmcduff
Turn off truck and walk away. Lights normally turn off after a minute but won't turn off now unless I do it manually. Just wondering if this has happened to anyone else. Don't have day time running lights on this truck. Thanks
Old Feb 1, 2015 | 04:28 PM
whitetmw's Avatar
whitetmw
What year? I'll see what I can find.
Old Feb 1, 2015 | 06:07 PM
sudsmcduff's Avatar
sudsmcduff
2003. Thanks
Old Feb 1, 2015 | 06:29 PM
whitetmw's Avatar
whitetmw
That function is controlled by the GEM.
Try un-hooking the battery ground cables from both batteries. Use a 18 AWG wire (or similar) from either battery ground wire to the negative post for a few minutes.
That drains all the capacitors. Hopefully, when you hook it back up, it will be okay.
**Pull codes first to see if something is going on.
Old Feb 1, 2015 | 06:43 PM
AllaboutMPG's Avatar
AllaboutMPG
Does the 03 have a GEM. Thought it was changed to another module by then.
Old Feb 1, 2015 | 07:21 PM
whitetmw's Avatar
whitetmw
Actually called a Body Control Module on 03 and later while they were setting up for the 6.0's.
They call it a Head Lamp/Body Module. Same principle, Just a different name. They also did away with the under hood distribution pannel in 03. The only separate modules were the Vehicle Security System Module (VSSM) and the Power Seat Module (DSM)
I understand people replace the circuit relays by soldering new ones in place.
Old Feb 1, 2015 | 09:02 PM
sudsmcduff's Avatar
sudsmcduff
Thanks for the info. I will try it
Old Feb 2, 2015 | 07:41 AM
bigb56's Avatar
bigb56
This is one of the symptoms of a VSM on it's way out, Autolamp is controlled by the VSM. When mine went out I could reset it by pulling fuse #19 for a minute then putting it back. This would "fix" it for a week or so but eventually it got much worse, courtesy lights would stay on, radio would stay on, doors would lock and unlock while driving down the road. I finally bit the bullet and had the dealer program and install a new VSM, fixed everything.
Not saying it couldn't be something else, but at least if you pull fuse 19 for a minute and it fixes it that pretty much narrows it down to the VSM.
Jimmymahaffey
Jun 2, 2019 12:54 PM
jarrodwiggins
Apr 24, 2014 05:55 PM
oldcoupe42
Electrical Systems/Wiring
13
Oct 10, 2013 04:20 PM
hotforteacher
Jun 19, 2012 01:34 AM
Smoove
2004 - 2008 F150
Dec 6, 2006 03:36 AM
