Sponsored by: Real Truck
Rear view mirror back up camera sensor
Old Feb 1, 2015 | 09:51 AM
Brandon Roberts's Avatar
Brandon Roberts
I have a 2009 f-250 super duty cabelas edition. I have just the regular radio in the truck with the sync but not the touch screen. My reverse camera shows on my rear view mirror and has the backup sensor button on the dash. When I start the truck the sensor shows that it's on. Once I put the truck in reverse and the camera shows up on my mirror the sensor button shows off. Can anyone help with my problem. I can post pics but just wanted to ask first and see if I could get a answer. Any help is appreciated! Thanks
Old Feb 2, 2015 | 07:03 PM
Brandon Roberts
After looking around on the web for a few days I found the problem. If anyone else has this issue just get in your truck turn the ignition over but not to where the truck is on. Throw your truck in reverse and if you go to the back bumper there are 4 sensors for the reverse camera. If you get close to each sensor they will have a little ticking noise. If one is not working then it needs to be replaced and will throw the rest off. I found the sensor on eBay for like $15 compared to $100 at a ford dealer. Hopefully this helps if anyone else has had this problem.
mutantsquirl
May 13, 2019 06:20 PM
Seven Gables
Jul 8, 2017 07:55 PM
reamer
Escape & Escape Hybrid
Mar 26, 2017 08:01 PM
woody367
Nov 13, 2014 05:00 PM
chopper chik
Jan 25, 2006 11:14 AM
