flexplate dilemma???
Old Jul 21, 2003 | 11:52 PM
NiteMan69's Avatar
NiteMan69
ok, i have a 91 Bronco 302, putting a 302 HO motor but changing to the original bronco stuff (intake, sensors etc.) My question is this...Do i use the flexplate from the HO or put my original (91 Bronco) back on. Is there a difference? I have the E4OD Tranny.
Thanks....
Old Jul 22, 2003 | 08:37 AM
fishin1976's Avatar
fishin1976
If I read correctly, the difference is the counter wieght. One is a 28 oz, the other is a 50 oz. Either way, use the one from the HO motor, it should work fine. Count teeth on the ring gear, as you may need a different starter. not sure on that though.
