cleanin rusty bores
Old Jul 19, 2003 | 08:08 PM
Njbmx's Avatar
Njbmx
cleanin rusty bores
hello, i just bought an '89 'stang gt engine w/ 99kmiles. i dont think i am going to rebuild the bottom end of this beast. but i looked at the bores, and there seems to be some surface rust. i sprayed the tops and bores down w/ rust penitrator. now my question is this: how do i get rid of the rust and make the block useable w/o tearing the whole bottomend apart? i want to replace and upgrade the heads, cam, intake manifold, timing chain, oil pan, water pump, basically the whole top end.
thanks
Old Jul 19, 2003 | 10:55 PM
AceTrucking's Avatar
AceTrucking
cleanin rusty bores
There is a litle honing tool yu can attach to a drill that can clean surface rust...i'm a little tired now and can't think of the exact name, but it works wonders.
Old Jul 20, 2003 | 08:45 AM
Yelrisheam's Avatar
Yelrisheam
cleanin rusty bores
cylinder hone. Don't take to much material off the cylinder side walls. With a cylinder hone, it takes a long time to do this, but I've seen it done.
Yelrihseam
Old Jul 20, 2003 | 09:43 PM
Diesel_Dummy _'s Avatar
Diesel_Dummy _
cleanin rusty bores
and you will have to remove the pistons, a ball flex type of hone works best
Old Jul 20, 2003 | 09:50 PM
Henry_the_Ford's Avatar
Henry_the_Ford
cleanin rusty bores
If you have it far enough down to get in the bore you might as well pull the pistons out. Its not that hard. Just mark EVERYTHING and I mean EVERYTHING so you get it all back in the same. If you dont you will throw a rod and bye bye block. I use a numbered punch set to mark caps, rods and direction of caps so it all goes back exactly the same.
Old Jul 22, 2003 | 10:45 AM
Njbmx's Avatar
Njbmx
cleanin rusty bores
i'm probably going to just hone the bores, and then reuse the stock forged rods, crank, and ifthe pistons are still good, use the stock forged pistons. but i will replace the bearings, and rings. does that sound ok on a block w/ 99k miles?
thanks
