Black Smoke
Old Jan 30, 2015 | 04:10 PM
kraigwy's Avatar
kraigwy
Black Smoke
I'm getting constant black smoke on my '07 6.0L F-250.
When its cold, its gray, but turns black when the engine is warmed up.
Also now it rattles like a Cummin's diesel.
I first noticed it at last fill up, first thought it was bad fuel but its getting worse.
Any idea of what the problem may be and/or a fix.
Still has lots of power. That hasn't changed.
Thanks in advanced.
Old Jan 30, 2015 | 04:45 PM
npccpartsman's Avatar
npccpartsman
Sounds like you have an injector leaking. Have you code scanned the truck?
Old Jan 30, 2015 | 05:15 PM
DSMMH's Avatar
DSMMH
Could that be injector STICTION?
Ed
Old Jan 30, 2015 | 05:34 PM
78fordman's Avatar
78fordman
More like a over fueling injector. Check for cylinder contribution codes.
Old Jan 30, 2015 | 06:14 PM
steelhead2's Avatar
steelhead2
Have a balance test done soon to find out which injector is bad. The rattle your hearing is your warning that bad things are about to happen.
Old Jan 31, 2015 | 06:12 AM
Awt2383's Avatar
Awt2383
And if you do end up changing your injector, don't drop the torx bit...
Forddiesel17
22
Feb 27, 2015 08:56 AM
bholicz
Nov 27, 2010 06:00 PM
tucker1999
Feb 17, 2009 09:56 AM
stockernavstar
Jan 13, 2006 12:40 AM
