Black Smoke
Old 01-30-2015, 04:10 PM
kraigwy's Avatar
kraigwy
kraigwy is offline
Black Smoke
I'm getting constant black smoke on my '07 6.0L F-250.
When its cold, its gray, but turns black when the engine is warmed up.
Also now it rattles like a Cummin's diesel.
I first noticed it at last fill up, first thought it was bad fuel but its getting worse.
Any idea of what the problem may be and/or a fix.
Still has lots of power. That hasn't changed.
Thanks in advanced.
Old 01-30-2015, 04:45 PM
npccpartsman's Avatar
npccpartsman
npccpartsman is offline
Sounds like you have an injector leaking. Have you code scanned the truck?
Old 01-30-2015, 05:15 PM
DSMMH's Avatar
DSMMH
DSMMH is offline
Could that be injector STICTION?
Ed
Old 01-30-2015, 05:34 PM
78fordman's Avatar
78fordman
78fordman is offline
More like a over fueling injector. Check for cylinder contribution codes.
Old 01-30-2015, 06:14 PM
steelhead2's Avatar
steelhead2
steelhead2 is offline
Have a balance test done soon to find out which injector is bad. The rattle your hearing is your warning that bad things are about to happen.
Old 01-31-2015, 06:12 AM
Awt2383's Avatar
Awt2383
Awt2383 is offline
And if you do end up changing your injector, don't drop the torx bit...
Forddiesel17
22
02-27-2015 08:56 AM
bholicz
11-27-2010 06:00 PM
tucker1999
02-17-2009 09:56 AM
stockernavstar
01-13-2006 12:40 AM
Quick Reply: Black Smoke
