Stock front spring hanger length
Old Jan 30, 2015 | 09:59 PM
J ballan's Avatar
J ballan
Originally Posted by Krazee Matt
As requested, pictures!
It's a full 9" from top to bottom. The depth is 2 1/8". Couldn't get a good angle with the flash for the width.
Tomorrow if you'd like I can try to get in there better and take full measurements of everything... Hole placement, material width, etc.
Nope that is quite good. Looks like the bolt centre to centre is right around 7". That should be more than enough info to get some fabbed up. Thanks again.
Old Jan 31, 2015 | 12:36 PM
IMASAP's Avatar
IMASAP
FWIW, I recently bought a pair of longer shackles on Amazon for about $51 with free shipping. If I recall correctly, they are 2 inches longer than stock for about an inch of lift. I haven't installed them yet, so no confirmation on the actual amount of lift I get. They are in a box with a bunch of other stuff I'm compiling for a spring time suspension revamp (too cold here now). I consider myself a do-it-yourselfer also, but couldn't justify the effort on making my own set when I can buy them done for about $50.
Linky
Amazon.com: Performance Accessories (1702) Leveling Shackle: Automotive Amazon.com: Performance Accessories (1702) Leveling Shackle: Automotive
Old Jan 31, 2015 | 01:18 PM
J ballan's Avatar
J ballan
Linky
Do you think you would be able to get me the measurements from bolt hole centre to centre sometime? Please and thanks.
Old Jan 31, 2015 | 01:29 PM
IMASAP's Avatar
IMASAP
On my shackles the holes are 7 and 3/4 inches, center to center.
Old Jan 31, 2015 | 01:31 PM
wpnaes's Avatar
wpnaes
Originally Posted by J ballan
Sorry for the confusion. I meant front leaf spring rear shackles. My bad.
No worries, the front hangers can be changed also if desired. Not as easy as shackles.
Old Jan 31, 2015 | 02:41 PM
J ballan's Avatar
J ballan
Right on thanks again. Looks like the stockers are right at 5".
Baatzy
Feb 21, 2016 08:03 PM
78Southwind
Nov 27, 2012 07:42 PM
YZGUYONE25
Jan 25, 2009 09:39 PM
boilermkr
Nov 26, 2006 12:04 PM
