How long can a engine run without a rad?
Old Jan 29, 2015 | 12:58 PM
good to doo's Avatar
good to doo
So I,ve got the clip off the truck, but I would like to move it in and out without having to hook up the rad. My plan is to connect the upper and lower hoses together with a connector and connect the 2 heater hoses into a loop. Do you think I should remove the t stat for this move or leave it in. I don,t think I,ll have the truck running for more than 3 or 4 min at a time, what you all think??? thanks
Old Jan 29, 2015 | 01:00 PM
HIO Silver's Avatar
HIO Silver
Until the piston rings weld themselves to the cylinder walls!!!
Old Jan 29, 2015 | 02:00 PM
46Whizzer's Avatar
46Whizzer
It should be fine for short periods of time
Old Jan 29, 2015 | 02:25 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
As long as you connect everything like you said, you should be ok for a short running time. I think taking out the t-stat is a good call also.
No breaking in a cam or major burn outs though...lol
Old Jan 29, 2015 | 06:00 PM
1320stang's Avatar
1320stang
If you're just driving it in and out of the garage, it doesn't even need water in it if you're not running it for more than a minute or so. Obviously less is better and no WOT.
Old Jan 29, 2015 | 06:04 PM
Skip1970's Avatar
Skip1970
take belt off so youdont run waterpump bearing if you run without water.
Old Jan 29, 2015 | 06:43 PM
79finally's Avatar
79finally
From a cold start, it take several minutes for your engine to come to operating temp(thermostat opening). If you connect the hoses with water in it, you can run it that same amount of time. Without water, just a bit less time. Don't try to rely on you temp gauge, it takes water temp.
Old Jan 29, 2015 | 06:52 PM
tbear853's Avatar
tbear853
I had the thought to say the same thing until I saw you already did ...
Yeah, without any coolant it'll heat up much faster than it will "with".
I'ld run coolant, not just water if it were mine and if I wanted to keep that water pump. I'ld connect the rad hoses with a piece of exhaust tubing and run a loop on the heater hoses. Coolant also is a better lubricant for water pumps plus this way, the gage tells you something.
g0rds350
16
Dec 15, 2009 01:55 PM
jason867
1983 - 2012 Ranger & B-Series
Jan 22, 2009 02:51 PM
FordF350Baby
Feb 4, 2008 10:43 PM
ken1mod
Aerostar
30
Oct 19, 2005 08:23 PM
JeffMasonCO
Aerostar
Jun 2, 2003 10:32 AM
