1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
2015 backup camera install questions
Old 01-29-2015, 08:00 AM
katoom400's Avatar
katoom400
katoom400 is offline
getting ready to purchase a backup camera system for my new 2015 f250 xlt. On my last truck (Tundra) the wiring was already there I just had to tap into it and install cheap camera in the tailgate handle and put a cheap monitor in the overhead sun glasses holder, the entire project cost me $38. Sure it's probably not the best quality but it served my purposes perfectly (hooking up to my travel trailer)
So I'm wondering if the same wiring may be present in the Superduty?
Old 02-08-2015, 09:33 AM
katoom400's Avatar
katoom400
Old 02-13-2015, 06:50 AM
katoom400's Avatar
katoom400
ok, after some searching it seems there is at least some wiring built into the "standard" harness.
what I need to know is:
1. looks like there is a plug in the back by the spare tire, what harness do I need to hookup an aftermarket camera at the rear end.
2. I just have the plain old rear view mirror without the compass, where does the camera harness terminate on the inside of the truck? is it up by the sunglass holder? behind the dash?
thanks,
Andy
Old 02-13-2015, 07:44 AM
Just Strokin's Avatar
Just Strokin
Just Strokin is offline
here are some part number and prices for the 2015 tail gate camera
Tailgate harness - FC3Z-14A442-A $11 + tax local Ford parts dept
Ford Camera - EC3Z-19G490-A $84 + shipping from Tasca Ford
FORD OEM Bezel - AL3Z-19H511-A $26 with free shipping on eBay
Ford Script - CL3Z-9942528-B $28 + shipping from Tasca Ford
You can pick up the video in the plug on the passenger side kick panel. Connector # C265. White w/green strip is video (+) pin 16, Brown w/violet strip is video (-) pin 15, and ground/shield is Black pin 17
Or connector C264, behind right hand side of instrument panel, near right A-pillar. White w/green strip is video (+) pin 4, Brown w/violet strip is video (-) pin 9 and black is ground/shield pin 8.
The above info is from the 2015 Ford Service DVD. If not correct, blame Ford.
Old 02-13-2015, 07:55 AM
katoom400's Avatar
katoom400
WOW...EXACLTY THE INFO I WAS LOOKING FOR!
is the camera complete with the outer cover? it's hard to tell.
Thanks Larry!
Old 02-13-2015, 08:19 AM
Just Strokin
The camera is water proof as sold. Mounts directly into the bezel listed above. The bezel replaces the one in the tail gate now.
Old 02-13-2015, 08:46 AM
katoom400's Avatar
katoom400
Thanks again Larry!
so if i purchase the above parts, I'm good all the way from the rear to the front kick panel or instrument cluster, from there I just run wires up to an aftermarket mirror/display in the visor? or am I better off going with a ford mirror/harness from the kick panel?
Old 02-16-2015, 08:03 AM
katoom400's Avatar
katoom400
can anyone tell me where exactly the harness connector is located in the rear of the truck or have a pic of it?
Old 02-16-2015, 10:07 AM
Just Strokin
It is pretty much center of the truck right close to the spare if there. It is possibly capped with and orange cover.
Old 02-16-2015, 10:21 AM
katoom400's Avatar
katoom400
Thanks again Larry!
I've been looking at this mirror:
OEM Replacement Rear view Mirror with 4.3" LCD Display for Back Up Cam | Tailgate Camera.com
that would put me right around $300 for all the parts. Do you know if there is a OEM harness that gets me from the passenger side kick panel to the mirror, or am I better off just running the wires down and soldering directly?
Old 02-16-2015, 11:22 AM
Just Strokin
Yes, there is a factory harness that routes the video to the mirror.
Looking at the mirror you have scoped out, I doubt you need this harness. The harness with your selected mirror routes power and video down to the dash level. I think you would have to find a way to connect the factor video wires to the RCA plugs of the mirror you have selected.
Old 02-16-2015, 11:35 AM
katoom400's Avatar
katoom400
Got it! was hoping maybe I could find the pinout for the factory harness plug and solder the mirror wires directly in. Found this, but not sure if it's what I'm looking for:
https://www.ford-trucks.com/forums/1...l#post11113679
Old 02-16-2015, 12:58 PM
Just Strokin
Hope these help....
Old 02-16-2015, 01:11 PM
Just Strokin
I believe this the part number for the harness that goes from connector C264 up to the mirror for the video. BC3Z-17K745-C Cost is about $20.00
Old 02-24-2015, 07:38 PM
katoom400's Avatar
katoom400
Got under the truck tonight looking for the plug, but did not find anything? is it possible it's under the spare tire? or not there at all?
Quick Reply: 2015 backup camera install questions
