Sanding bed
Old Jul 21, 2003 | 10:23 PM
herdfan75's Avatar
herdfan75
Talking Sanding bed
I'm sanding the bed on my 69 F100, and someone has filled up the body line seam with bondo. Any good ideas how to get that out? I've tried a sand blaster (small one on 100 lbs. pressure) and a DA sander (80 grit) with little success. I guess I'll try a grinder next to get the bulk of it. Paint stripper makes too much of a mess.
Also, any tips on sanding the inside of the holes at each corner (where you can put a rack).
Thanks.
Old Jul 21, 2003 | 10:43 PM
HillbillyHellcat's Avatar
HillbillyHellcat
Sanding bed
Try using a paint stripping wheel made of that rough plastic stuff - I stripped an entire car this way. Be sure to wear a mask when grinding away filler as it makes a lot of dust.
Old Jul 22, 2003 | 07:36 AM
Huntsman's Avatar
Huntsman
Sanding bed
I have heard that heating the bondo with a propane torch or heat gun will soften the bondo enough that it can be dug out. I have never had the oppertunity to try it. Be careful you don't get so much heat that you warp the sheet metal.
Old Jul 22, 2003 | 02:48 PM
Aekisu's Avatar
Aekisu
Sanding bed
This is what I would use. It's looks like Scotch-Brite on a round pad. The pad is spun by a die grinder. 15,000 r.p.m. really strips the paint off and is nearly harmless to the sheet metal.
